Noise from computer digital coaxial to a/v receiver ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-03-2013, 05:26 AM - Thread Starter
aznbladez's Avatar
I recently upgraded my computer and now there is noise coming from the speaker tweeters. The cable is connected to the A/V receiver using digital coaxial from my MSI motherboard. Everything else is the same. It makes even more noise every time I move the mouse also. I'm using a Crown XLS1500 amplifier which had noise before but this is much much worst.
aznbladez is offline
post #2 of 4 Old 07-03-2013, 02:14 PM
Selden Ball's Avatar
Quoted: 3430 Post(s)
Liked: 1700
Unfortunately, what you've written indicates that while you might have upgraded your computer's speed and graphics, you have managed to degrade its audio. You're hearing the crosstalk between the motherboard's digital and audio circuitry. If your computer's video card has an HDMI output and your receiver has an HDMI input, you might try using that instead.
Selden
Selden Ball is offline
post #3 of 4 Old 07-03-2013, 05:26 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 741
Since your interconnect is digital, the noise must be traveling over the ground wire of S/PDIF cable. Do you have the option of using Toslink optical digital? That would break the electrical connection.
amirm is offline
post #4 of 4 Old 07-04-2013, 06:07 AM - Thread Starter
aznbladez's Avatar
Yes I tried optical cable and it worked fine. I guess the motherboard is the problem
