How can I get stereo from my PC to my audio system? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-13-2013, 08:58 AM - Thread Starter
eljr's Avatar
Quoted: 1193 Post(s)
Liked: 9062
I want to watch the video from my PC on my TV and listen to the audio through my audio system.
If I use the HDMI connection from my PC to TV the audio goes to my TV and the speaker jack is overridden.
Any ideas?
ELJR's "listening" blog.
eljr is offline
post #2 of 10 Old 07-13-2013, 09:51 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Your TV should have a digital audio output. Send that to the sound system.
BIslander is offline
post #3 of 10 Old 07-13-2013, 10:40 AM - Thread Starter
eljr's Avatar
Liked: 9062
Yes it does,I know, thanks. This is what I am trying to avoid.
Long story short I'd need an electrician to come run the wire because it snakes through so much wall and rooms.
I have one HDMI and one set of those multi colored connects/wires from teh tv to the sources. I have to work with these or as I said I'll need an electrician.
eljr is offline
post #4 of 10 Old 07-13-2013, 11:45 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
If those multicolored wires are component video cables, you can use one of them for digital audio. Assuming your TV has an optical rather than coax output, just get an optical-coax converter.
post #5 of 10 Old 07-13-2013, 12:14 PM - Thread Starter
eljr's Avatar
Liked: 9062
I am going to solve it by buying a Blue Ray player with HDMI inputs and use the RCA audio outputs to my Nad and the HDMI for the picture to the set.
eljr is offline
post #6 of 10 Old 07-13-2013, 12:18 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
That will work, too. But, be careful because some newer players lack analog stereo outputs.
post #7 of 10 Old 07-13-2013, 01:34 PM - Thread Starter
eljr's Avatar
Liked: 9062
thanks
eljr is offline
post #8 of 10 Old 07-13-2013, 02:13 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
? a player has no inputs.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #9 of 10 Old 07-13-2013, 02:22 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Take a look at the Oppo 103.
post #10 of 10 Old 07-14-2013, 12:34 PM - Thread Starter
eljr's Avatar
Liked: 9062
Yes, the 103 is perfect.
eljr is offline
