Using two subwoofers on a home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-13-2013, 09:24 PM - Thread Starter
MultiStory's Avatar
Hello, recently i got a home theater 5.1 system. However there was an extra subwoofer in my cabinet that can be used. Can i plug both the subwoofers into the same amplifier?(join both the wire and put into the same plug) . sorry i'm not tech savvy.
MultiStory is offline
post #2 of 4 Old 07-14-2013, 05:44 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Yes and all you need is one of these.
MultiStory likes this.
William is offline
post #3 of 4 Old 07-14-2013, 07:04 AM
mtn-tech's Avatar
Quoted: 233 Post(s)
Liked: 180
If you are using an AVR (receiver) and the LFE output to two powered subs, buy an RCA splitter to split the signal and run a separate RCA cable to each sub - this signal can be split no problem. If you are using an actual "amplifier" to drive a passive sub (rare) connecting another sub may be an issue and more research would be needed.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #4 of 4 Old 10-31-2013, 01:54 AM - Thread Starter
MultiStory's Avatar
Thanks for helping, my problem is solved.
