Is burlap by itself enough to wrap Roxul RHT 60 - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2013, 09:08 AM - Thread Starter
pjoseph24's Avatar
Wondering if burlap by itself will allow fibers to escape from acoustic panels, I was thinking may need to cover with a tighter (not sure if "tighter" is correct term) fabric first but not sure?
thanks
pjoseph24 is offline
Old 07-16-2013, 10:34 AM
brandon_k_w's Avatar
Burlap is too porous IMO, not to mention the material is ugly. The panels will constantly be hanging on your wall, so depending if you care about your room's aesthetics go with something color coordinated as you'll forget the extra $50 you spent once a few days pass, but the better aesthetics you'll keep reminding yourself constantly when you look at them. I was able to find a cotton fabric that is tighter than burlap but thin... once I held it up to light I could easily see through it.
brandon_k_w is offline
Old 07-16-2013, 11:12 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Last time I looked in the local fabric store, they were selling heavy felt for the about the same price as burlap. Seems like a better choice both for appearance and for capturing fiberglass shed.
It is best if the fabric covering is fire resistant. Some burlap smells like it has absorbed some mineral oil, and that's running the exact opposite direction.
Products like this really work:
http://www.firetect.com/ourproducts.htm
We applied a product like this to felt by cutting the felt to size, saturating the felt with the fire retardant liquid and then putting it through a spin cycle in our washer, and capturing the fluid ejected during the spin cycle and recycling it.
arnyk is offline
Old 07-16-2013, 12:24 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Fibers won't escape unless you literally bang on the wrapped panels with a broom stick. biggrin.gif
Felt and dyed burlap are both good choices.
--Ethan
Ethan Winer is offline
