acoustic panel & Sub placement help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-23-2013, 03:35 PM - Thread Starter
pjoseph24's Avatar
Visio-Room Layout 3.pdf 25k .pdf file
Pleasesee attached room layout photo.
I am in the process of building acoutic panels, I have completed one corner trap as of now.
Regarding the back wall behind the couch, I was thinking of putting some panels horizontally that are at least 4" thick, I was wondering if they would be more effective mounted on the wall starting at a height that is equal to the back of the couch or should I start at the bottom, which is basically behind the couch?
Also i listed two other possible options to place the sub if anyone has any input on that.
pjoseph24 is offline
post #2 of 3 Old 07-24-2013, 11:32 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
The back wall panel should be as big as possible, centered on your seated ear height.
A thickness of 4", w/equal 4" gap would be even better.
Sub placement is determined by measurement, ... ideally. Try everything, and don't be afraid to try the position along the same rear wall behind the seating. With a low crossover, and very careful time/phase alignment, you could benefit from greater nearfield output, smoother nearfield response. Just a thought, .. experiment extensively with sub placement, it'll pay-off for sure.
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #3 of 3 Old 07-24-2013, 02:50 PM
JWL-Realtraps's Avatar
There are 2 problems to solve with rear wall traps. First are high frequency reflections from the speakers. Second is the bass buildup that usually exists on the rear wall. Thick panels will address both problems.
For the former (high freqs), place them at ear level. For the latter (bass), you might get better performance with the panels in the corners (wall/ceiling and/or wall/floor).
For more detail on rear wall strategies, see: http://realtraps.com/art_rear_wall.htm
JWL-Realtraps is offline
