Need help audio/video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-01-2013, 06:34 PM - Thread Starter
sOopAirmario's Avatar
My ps3 has hdmi running to a Vizio and optical running to a sony digital audio control center (surround sound). I do not have remotes for my tv nor the surround sound. I can not figure out how to make my surround sound play the optical. the optical input is under the digital cataglory. I cannot find the input selector for the optical on the surround sound. What options do i have to make sound go from playstation to surround sound and still be able to run the hdmi to the tv. My surround sound has no hdmi ports on it unfortunatly. What can I do?
sOopAirmario is offline
post #2 of 8 Old 08-01-2013, 06:40 PM
Sweetmeat's Avatar
Quoted: 307 Post(s)
Liked: 74
My ps3 is in storage right now, so I can't tell you exactly, but I think what you might need to do is go into your ps3 audio settings and choose optical instead of hdmi. Then, assuming your AVR is set to the input for which you plugged your optical cable into (game, TV/Video, etc), you should have sound from your AVR and not your TV. If it's already setup that way and you're still not getting audio from your AVR, reply back.
PN59D8000 and JVC RS420 with Elite 120" screen
Receiver - Yamaha RX-A3060, WXA-50 MusicCast Amp for Zone 2
Front - CM9, Center - CMC2, Side Surrounds - DS3, Rear Surrounds - CM5, Front/Rear Atmos - CCM663, Subs - PB12+ and PB13 Ultra
Remote/Streaming Media Players - Harmony Elite, Apple TV 4, Nvidia Shield Pro - use with HDHomeRun Connect/Extend and Plex
Sweetmeat is offline
post #3 of 8 Old 08-01-2013, 06:53 PM - Thread Starter
I cannot set my surround sound to where it will play the optical input. I cannot figure out how. Playstation is already set to play sound through optical cable and video though hdmi. I think I just need to find a good remote for my surround sound where I can switch features and make it to where it's playing through the optical cable? Would you have any suggestions on where to get it from and what brand to get?
post #4 of 8 Old 08-01-2013, 07:01 PM
Sweetmeat's Avatar
Quoted: 307 Post(s)
Liked: 74
You shouldn't have to set anything in your AVR to use optical vs. HDMI. If you think that there is a setting in your AVR, I would find the owners manual online and read through it to find how to change that setting.
Are you sure your AVR is set to the input where you plugged in your optical cable?
I really think this is a PS3 setting that needs to be changed though. Maybe do a search on ps3 optical.
post #5 of 8 Old 08-01-2013, 07:06 PM
Sweetmeat's Avatar
Quoted: 307 Post(s)
Liked: 74
Check out the last post on this link.
http://community.us.playstation.com/t5/PlayStation-General/No-Sound-from-PS3-through-HDMI-to-TV-then-Optical-Cable-to/td-p/6568865
post #6 of 8 Old 08-01-2013, 07:09 PM
Sweetmeat's Avatar
Quoted: 307 Post(s)
Liked: 74
Another great link, and this explains the problem I was thinking of. Its around the 3rd post or so.
http://www.avsforum.com/t/768498/anyone-else-still-having-ps3-optical-out-problems
post #7 of 8 Old 08-01-2013, 07:32 PM - Thread Starter
no im pretty sure that its because I do not have my surround sound on the right input. since i dont have the remote, i can only play sound out of video 1, video 2, dvd, sa-cd/cd, fm, and am. I have to have the remote to switch from video 1, video 2, ect. to digital or optical input. By any chance do you know of any way i can make it to where audio is through rca and video is though hdmi?
post #8 of 8 Old 08-01-2013, 07:52 PM - Thread Starter
Nevermind. I figured it out. I went onto audio settings in playstation and put it though rca. Easier than I thought. biggrin.gif
