Downsides to playing music over wifi into an Apple TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-12-2013, 05:10 PM - Thread Starter
abrian's Avatar
Does the audio quality suffer if it's played over wifi? I have the ATV hooked up to a Fiio E17 > Yamaha RX-V367 > PSB T6. I was figuring as long as the audio signal makes it to the ATV, the DAC will take care of converting it into a clean signal. But I'm not sure, which leads to the question, is playing over wifi even worth it besides the convenience?
abrian is offline
post #2 of 5 Old 08-12-2013, 07:11 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
No. WiFi has more than enough bandwidth to carry lossless signals.
abrian likes this.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 5 Old 08-12-2013, 07:11 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Brian,
Welcome to the forum.
No.
It would be a little delayed, and in some circumstances you could get drop-outs, but the audio-quality will be the same as if it was hard-wired.
Edit:
Mcnarus beat me by 9 seconds!
abrian likes this.
MarkHotchkiss is offline
post #4 of 5 Old 08-13-2013, 03:53 PM
alexwgoody's Avatar
No Hi-res streaming, but that's may not be an issue for you. apple tv maxes out at 16/48 iirc
alexwgoody is offline
post #5 of 5 Old 08-13-2013, 04:19 PM
jtbell's Avatar
I've used an Apple TV to play lossless files from iTunes for two and a half years. Until a couple of weeks ago I used a wireless network. Only very occasionally did I have signal dropouts because of interference or whatever. Now I use powerline network adapters for higher bandwidth, so I can stream high-definition video also.
Sound quality hasn't been an issue for me. I listen mostly to classical music, feeding the Apple TV into an NAD receiver and PSB Image B25 bookshelf speakers. The sound is identical (as far as I can tell) to a CD played on my Blu-ray player, connected (like the ATV) to the receiver via HDMI.
jtbell is offline
