Optimal way to connect AC - Sub, Receiver, Belkin PF30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2013, 10:47 AM - Thread Starter
logicology's Avatar
I have a Belkin PF30 power conditioner. A Onkyo SR805 receiver. And a Rythmik D15SE subwoofer.
I read somewhere that plugging receivers and powered subs into a power conditioner is a bad idea. Something about when power needs get high, the conditioner will clamp down on power and possibly damage the amp (???). It doesn't make much sense to me... but plugging my receiver and subwoofer into my PF30 is the only way so far I've been able to clean up my hum.
Is this an OK solution? Will I damage my equipment? Or should I continue looking harder to fix the hum problem? (House is grounded properly, cable line is newly grounded at the box, etc...)
Lastly, in the image below you can see there are 3 banks of outlets. Video, Audio, and a single "Hi-Current" outlet. Should I plug the sub or the receiver in the Hi-Current outlet? I can only choose one...
Thank you everyone!
logicology is offline
post #2 of 4 Old 08-13-2013, 11:15 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I have everything plugged into my strip, except my 5 channel power amp, including two subs.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 4 Old 08-13-2013, 11:21 AM
fokakis1's Avatar
Quoted: 49 Post(s)
Liked: 52
Plug your sub into the high current slot.
Control4 Automation Programmer
fokakis1 is offline
post #4 of 4 Old 08-13-2013, 11:38 AM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
This kind of power center (with MOV protection circuits) offers some limited protection against surges and has a warranty for connected equipment , but only if EVERYTHING goes through the power center. If you plug anything directly into the wall or any incoming signal comes from a device plugged into the wall your protection is bypassed and your warranty is void.
Consult your power center manual - check the amperage of the filtered outlets to see if they are sufficient for your AVR or your sub. If not, check to see if the power center allows you to split the high current outlet using a high current power tap. Barring both of these solutions, you could connect your sub to a separate 15 amp surge protector that also isolates the RCA signal cable connecting the AVR and sub basically making them two isolated systems - like this one. I did this in the past when my sub was on a different side of the room:
http://www.panamax.com/Products/Other/MD2-AV.php
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
