Basic Home Theater - Choosing an SPL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-22-2013, 07:27 AM - Thread Starter
rockncountry101's Avatar
I set up a HTIB (LG lhb 536). My room is small, but I need a device to measure the different levels. I had searched the internet over and over and could find no advice on what kind of SPL to buy. I kept seeing max hold/weighting/slow/fast. I was lost. Do I need to buy an expensive meter or will one of the cheaper ones work. Any advice would be greatly appreciated. Thanks in advance!
rockncountry101 is offline
post #2 of 6 Old 08-22-2013, 08:41 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
What exactly are your goals?
It's relatively unusual to see someone wanting to spend money on an SPL meter when they have a HTIB...
What exactly about the "max hold/weighting/slow/fast" is confusing to you? Do you understand what an SPL meter does and how it works?
walterappleby is offline
post #3 of 6 Old 08-22-2013, 08:50 AM - Thread Starter
My system doesn't have a self calibration function. No mic or anything. I borrowed a friend's SPL that he got from Radio Shack for about $100 and I measured each speaker and it made a world of difference. I've since moved the speakers around and need to recalibrate. I bought the Disney WOW disc that everyone is crazy about to maximize my sound experience. I do need an SPL though and want to make sure that I get the right device. Amazon has some for under $30 and I didn't know if they would work or not.
post #4 of 6 Old 08-22-2013, 01:05 PM
Ethan Winer's Avatar
Quoted: 265 Post(s)
Liked: 359
For calibrating speaker volume levels, even a $30 SPL meter should be fine. Where more expensive models shine is a flatter / more extended frequency response, better absolute volume accuracy (not needed here when setting relative levels), and a wider total SPL range. This might help:
All About SPL Meters
--Ethan
Ethan Winer is offline
post #5 of 6 Old 08-22-2013, 10:21 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
Check eBay for a used RadioShack SPL meter.
Mrkazador is offline
post #6 of 6 Old 08-23-2013, 06:29 AM
Skytrooper's Avatar
Quoted: 222 Post(s)
Liked: 144
Good reading about SPL Meters, Ethan.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
