Running different gauge speaker wires. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-26-2013, 07:12 PM - Thread Starter
flute's Avatar
Just moved into a home that has 16 gauge speaker wire already run through the walls connect to a wall plugin outlet. My question is can I run a short 2ft 12 gauge wire from my receiver into the wall outlet, thereby connecting to the 16 gauge wire in the wall.
Will this affect the sound in any way or cause a hazard. I also have some 14 gauge lying around I can use. I'm just all out 16 gauge and I'm lazy! biggrin.gif Your opinions are greatly appreciated.
flute is offline
post #2 of 5 Old 08-26-2013, 07:15 PM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
Running 12 or 14ga for that two feet is no problem at all. Some could argue it's less resistance for that two feet! rolleyes.gif
But it really won't make any difference. Personally I would just use the 14ga because it's thinner and easier to manage for two feet.
Glimmie is offline
post #3 of 5 Old 08-26-2013, 07:16 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
No, whether you use 12 or 14g.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #4 of 5 Old 08-26-2013, 07:18 PM - Thread Starter
flute's Avatar
great thanks folks thats all i need to hear!
flute is offline
post #5 of 5 Old 08-27-2013, 01:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Given the short length, you can use anything from many zero power bus (copper conductor as big as your wrist) to probably even 24 gauge.
arnyk is offline
