Pioneer VSX-822 No Sound with iPhone - AVS Forum | Home Theater Discussions And Reviews
Old 08-29-2013, 12:10 PM - Thread Starter
michaelscott's Avatar
I DO NOT have this hooked as an A/V unit. It's strictly being used as an outdoor receiver for music. I have the speakers hooked up to it and that's it. I connect the iPhone for music, but no sound. Just simply shows a file folder and then toggles back to original setting. Any suggestions or special settings that need to be applied?
michaelscott is offline
Old 08-29-2013, 04:56 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
How are you connecting the iPhone? USB? For whatever input you are using on the receiver, did you make sure the type of input (usb, composite, etc) matches? Nothing in the manual helps?
lovinthehd is offline
Pioneer Vsx 822 K 400w 5 Channel A V Receiver Network Ready Pandora Ipod Iphone Black
