Question about sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-31-2013, 12:09 PM - Thread Starter
Hip2bSquare's Avatar
Im about to purchase a soundbar and my question is:
In order to get 5.1 sound out of my soundbar from multiple consoles (PS3, TV, HD Cable TV Box, Blu ray player) i'll need a Optical or HMDI audio switcher right?
Here's a link : http://www.amazon.com/gp/product/B00B1V14XO/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A31DV9LWMQNJY6
Reason I ask is, I heard if I don't get a switcher; I won't be hearing true 5.1 DTS. Which means it will downconvert the sound right?
Someone please help me with this.
Hip2bSquare is offline
post #2 of 14 Old 08-31-2013, 01:39 PM
monkiboy48's Avatar
What soundbar are you purchasing? If your soundbar only has one optical in, then yes you would need an optical switcher.
Experience with the following gear: Cambridge Audio 640R; Cabmridge Audio 752BD; Rotel RCD-1072; Pioneer BDP-05FD; Emotiva UPA-7; Sherbourn PT-7020A; Manley Labs Stingray Integrated; Totem Acoustics Rainmaker Center; Totem Acoustics Hawks; Totem Acoustics Tribe I and II; Totem Acoustics Mask In-Ceiling; Adams Audio MK3 Pencil; Onkyo PR-SC5530; JL Audio Fathom and Dominion; Integra RDA-7; Lexicon LX-5; Arcam Muse; Sonos
monkiboy48 is offline
post #3 of 14 Old 08-31-2013, 02:53 PM - Thread Starter
Vizio S4251w-B4
post #4 of 14 Old 08-31-2013, 03:03 PM
monkiboy48's Avatar
You will need an optical switcher like the one you linked, or a coaxial switcher (depends on if your component's digital output are optical or coaxial). Although it seems like you've got it figured out and are on the right path with the optical switcher that you linked.
post #5 of 14 Old 08-31-2013, 03:17 PM - Thread Starter
Thanks man. So yea i will purchase that switcher.
post #6 of 14 Old 08-31-2013, 03:25 PM - Thread Starter
Was I right about the sound converting also without the switcher?
post #7 of 14 Old 08-31-2013, 05:31 PM
monkiboy48's Avatar
Not sure what you mean. The switcher allows you to "connect" four each devices to your single optical input on your soundbar. The soundbar can decode Dolby Digital or DTS Digital Surround.
Without the switcher, you will only be able to connect and decode one device at a time. Please explain what you mean by "sound converting".
post #8 of 14 Old 08-31-2013, 05:43 PM
Possumgirl's Avatar
Liked: 58
As you've probably learned from the Soundbar forum, most HDTVs downconvert audio from connected devices to 2 ch. stereo. By connecting the audio from each of your source devices to the switcher, you'll be sending 5.1 (when available) directly to the soundbar.
Possumgirl is offline
post #9 of 14 Old 09-01-2013, 10:05 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
A soundbar can only actualy provide 2 (or maybe 3) channels of sound since there are no REAR speakers....duhhhhh.
Just use the optical audio output of the TV to go to the soundbar, and feed all of the sources into the HDMI or Component-video inputs of the TV.
If you need a switcher, due to the number of components, install the switcher BEFORE the TV inputs.
commsysman is offline
post #10 of 14 Old 09-01-2013, 10:50 AM
Possumgirl's Avatar
Liked: 58
Well, in the case of this particular soundbar, there ARE rear speakers. Hence the reason for sending 5.1 audio to the soundbar. duhhhhh
post #11 of 14 Old 09-01-2013, 11:50 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Actually there are front speakers that are reproducing the surround channel content. It isn't the same thing as having surround speakers located beside or behind the listener.
FMW is offline
post #12 of 14 Old 09-01-2013, 12:36 PM
Possumgirl's Avatar
Liked: 58
Here is the Vizio product page for the soundbar in question. It DOES have two wireless satellite speakers in addition to the LCR in the "bar" portion. It is one of three soundbars that I know of that have five actual speakers, making them 5.1 systems as opposed to the usual 2.1 or 3.1 soundbar.
http://store.vizio.com/s4251wb4.html
post #13 of 14 Old 09-01-2013, 02:59 PM
FMW
FMW's Avatar
Liked: 1684
I'm sorry. I spoke without doing the appropriate research. Yes the product does have surround speakers.
FMW is offline
post #14 of 14 Old 09-02-2013, 04:49 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It would appear that you don't understand how sound bars work. The more sophisticated of them use directional speakers and phase/time shifting networks to create a distinct spatial perception of the surround channels.
Even the ones that don't blend the surround channels into the front speakers so that you hear them, just not from a distinct spot.
arnyk is offline
