Using Audessy Eq to flatten Frequency (question) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-17-2013, 06:56 PM - Thread Starter
serialmike's Avatar
Hi all. Thanks in advance.
My situation is this. Have Klipsch RF82 fronts and RC62 center. I measured them in my last house but never corrected. Mv them to a new house with completely different room and came I with similar respone. The klipsch Reference series seems to have a dip at 1k and 2k that runs about 5db.
So I corrected for this by raising them in the Audessy eq. It dawned on me however that there are two approached to this. You can do s I did And simply raise the 1k 2k 5db. It occurred to me tonight that you could go another route by dropping the other frequencies to match the dip.
If I had to guess its best to do as I did. I figured I will simply ask. Which is the best way?
As an side note. After adjusting the speakers they are completely different and it is amazing. As you may or may not know 1k 2k is human voice range and many people complain of klipsch voice in movies. This it seems to me is the reason. Also so many reviews call the speakers bassy and forward sounding. This is also why. Incredible.
serialmike is offline
post #2 of 11 Old 09-17-2013, 08:50 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Most authorities will tell you that the best equalization is the one that does the most cutting of amplitudes. Cut before boost is a common guideline.
As long as you don't exceed the dynamic range of your system and cause distortion, it really doesn't matter. The cut before boost rule tends to reduce the probability of exceeding the dynamic range of your system with clipping, but it also includes the risk of making the system more noisy.
serialmike likes this.
arnyk is offline
post #3 of 11 Old 09-18-2013, 05:39 AM - Thread Starter
serialmike's Avatar
First, thank you for the response.
In response to your reply I add the system to reach reference levels is calibrated to -2 to -4db on the speakers. This means that for the dip at 1k and 2k frequency they are about 1 to 3 db over 0 at reference volume on the amp when adjusted. Hope that makes sense.
I tend to agree with cut rather than boost which is why I asked but with that said cutting the higher frequencies to match the dip would then mean that most of the frequency range would be boosted at 1-3 db over 0 at reference volume as I would then need to boost the overall speaker levels once adjusted.
I guess in this situation where the amplification matches the room so close trying it both ways and seeing which is best is best.
Also of note I very rarely listen to movies of tv over -15db on the dial. Music if the source is low I can get up there around -8 to -5
The receiver is a denon 1913.
post #4 of 11 Old 09-18-2013, 06:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It makes sense and it is small enough that it probably doesn't matter whether you boost or cut.
A lot of guidelines like this one come from live sound which is kinda like meatball surgery and involves 10-15 dB eq at times.
If you have to boost so much of the spectrum to use a cut at the point of eq then you've turned the advice on its head and I don't recommend that.
Or, apply the rule: "If its not broke, don't fix it".
I don't listen to much over -15 to -10 as well, and have have about 3 dB headroom over reference level, so we have yet another case where the AVR amps are more than adequate.
Speak of the devil. That's my new AVR. ;-)
arnyk is offline
post #5 of 11 Old 09-18-2013, 07:35 AM - Thread Starter
serialmike's Avatar
post #6 of 11 Old 09-18-2013, 05:39 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
Hey Mike,
Another common rule of equalization is minimal filtering. It simply makes no sense to throw out a whole slew of filters to reduce response across the board to address a single problem at 1-2 kHz. That basically has the equalization functioning as a level control, which is really poor form.
But for the sake of argument, let’s go with that. So you cut response by say, 5 dB everywhere above 1-2 kHz, and everywhere below 1-2 kHz. Well, if you electronically cut the entire frequency spectrum everywhere except at 1-2 kHz, what to you end up with? Quite naturally, a 5 dB spike at 1-2 kHz!
In other words, you’ve accomplished the same exact thing as if you had simply applied a filter or two at 1-2 kHz boosted 5 dB.
Improved headroom one way or the other isn’t an issue. With the all-cut scenario, you’ve lowered your output across the board by 5 dB. So you know are going to basically run the system at a higher volume setting than you were before, to make up for it. So, say “goodbye” to any headroom you thought you saved by going the cut-only route. Indeed, as Arny indicated, this method may well get you increased overall system noise.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #7 of 11 Old 09-18-2013, 05:46 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Are you using the Audyssey Pro Kit or simply the manual EQ built into your receiver, which is not Audyssey?
primetimeguy is online now
post #8 of 11 Old 09-18-2013, 07:49 PM - Thread Starter
serialmike's Avatar
I do not have pro. I have to goto Audessy and enable eq and then use a manual adjust. I thought that is Audessy.
Anyway, I stayed with the boost 1k and 2k ended up being just 3 or 4db. I don't hear noise or distortion so far. Much improved sound. Now voices are so much better as 1-2k is where voice is. Opened the speakers up tremendously.
Toggling eq on and off confirms much improvement. If I blind listened to them I would think they were 2 different speakers with the default sound being muffled garbage.
post #9 of 11 Old 09-18-2013, 08:28 PM
Quoted: 556 Post(s)
Liked: 359
Glad you like the improvement.  Just note that by using manual EQ you are no longer using Audyssey so any EQ that was done to the sub and other channels is now not in the chain.
post #10 of 11 Old 09-18-2013, 08:58 PM - Thread Starter
serialmike's Avatar
Never used Audessy. Prefer the natural surround processing setup properly. I'd rather have this dip fixed. Thanks didn't know that though.
post #11 of 11 Old 09-19-2013, 03:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Which makes a point - Audyssey can make the showroom sound of speakers far less of an issue.
arnyk is offline
