Setup 4 speakers on a stereo, impedance ? - AVS Forum | Home Theater Discussions And Reviews
Old 09-18-2013, 02:21 PM - Thread Starter
victorml's Avatar
Hi everyone,
Victor, 24 from France.
I have a quick question that has probably been asked thousands of times, and i've looked online but I still can't quite figure out if I can do what I wanna do.
I have a stereo that came with 2 speakers.
On the back of the stereo, impedance is, i quote : 4-16ohm.
I have two 3 ohm Speakers and 2 8ohm speakers.
Question : is there a way I can have all those speakers plugged in the stereo ?
Thanks in advance,
Victor
Edit : no idea why I said I was 24, I'm 26.
victorml is offline
Old 09-18-2013, 03:56 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
It's alright. I'm nearly 70 and I try to forget my age all the time. Putting two speakers on the same output will halve the impedance. So you would end up with a 4 ohm speaker and a 1 1/2 ohm speaker. Will that work? Maybe. Try it. Don't apply much power and see if the amplifier overheats. If it doesn't you will probably be OK.
FMW is offline
Old 09-18-2013, 04:42 PM - Thread Starter
victorml's Avatar
Thanks for the reply.
So :
On the left output, I plug in 2 speakers, one 8ohm and one 3 ohm, so impedance on the left is 4+1 1/2 = 5.5, which is in the range of my stereo (4 to 16 ohm).
So it should work. Unless calculations should be made per speaker instead of what I jus did, per output......
I'll try tomorrow, speaker by speaker...slowly, gently...
victorml is offline
Old 09-18-2013, 04:47 PM
SAM64's Avatar
Liked: 78
Two 8 Ohm speakers in parallel will result in a 4 Ohm load.
Two 3 Ohm speakers in parallel results in a 1.5 Ohm load.
An 8 and a 3 in parallel results in a 2.2 Ohm load.
Safest bet is to put an 8 and a 3 in series for an 11 Ohm load.
SAM64 is offline
Old 09-18-2013, 04:50 PM - Thread Starter
victorml's Avatar
Alright thanks !
Just to be sure, in series = plug 2 reds in the red socket, and 2 blacks in the black socket. And same on the right output. Correct ?
victorml is offline
Old 09-18-2013, 04:54 PM
SAM64's Avatar
Liked: 78
No.
In series, plug the red from one 8 Ohm speaker into the red socket, plug the black from one 3 Ohm speaker into the black socket, connect the black form the 8 Ohm speaker to the red on the 3 Ohm speaker.
SAM64 is offline
Old 09-22-2013, 04:45 PM - Thread Starter
victorml's Avatar
Just did that, works fine. Good power, no overheating after 5-6 hours a mid volume. Thanks thanks guys
victorml is offline
