Powered Soundbar, Speakers, and a Receiver - AVS Forum
post #1 of 3 Old 09-24-2013, 09:32 AM - Thread Starter
Brett3rThanU's Avatar
Essentially what I'm trying to accomplish is to have a powered soundbar, a receiver, and my new HDTV all play nicely. Right now I have my TV optical out to the reciever playing out of my speakers. However now I'd like to use the soundbar most of the time, however occasionally I want to be able to use my outdoor speakers which are connected to the receiver. If I leave all the connections the same as I have right now and plug the optical out on the receiver to the soundbar, will both the speakers and the soundbar be able to play TV sound/music at the same time? Is what I'm trying to do possible?
TV: Vizio M501d
Soundbar: Vizio SB4020m-B0
Receiver: Denon AVR-2803
Brett3rThanU is offline
post #2 of 3 Old 09-24-2013, 01:22 PM
arnyk's Avatar
Quoted: 390 Post(s)
Liked: 1034
TV: Vizio M501d
There are such things as optical splitters:
http://www.cablestogo.com/product/27027?utm_source=Google&utm_medium=Shopping&utm_campaign=SEM&gclid=CLSCvYHu5LkCFROZ4AodkWkAvw
Hook both the AVR and the Soundbar to the TV via one of these and turn on the device you want to listen to.
arnyk is online now
post #3 of 3 Old 09-24-2013, 04:53 PM
Possumgirl's Avatar
Liked: 58
Using an optical switch as Arnyk suggested is probably the best way. I don't know if you'd get audio from both your speakers and the sound bar by going optical out from receiver to sound bar, but even if it does work, the result may not be pretty. Having both playing at the same time would likely create an "echo" sound, plus the tonal qualities would be different and may not sound good together.
Possumgirl is offline
Reply Audio theory, Setup and Chat
User Tag List
