Amp RMS Greater Than Speaker RMS - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2013, 03:47 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Originally Posted by Skytrooper View Post
A few weeks ago a friend stopped over and we enjoyed some CD's from the 60's and 70's for a few hours at very high volume levels. Yes, we consumed a lot of beer. My friend suffers from Tinnitus ( constant ringing in the ears ) I saw him the next day and the ringing in his ears was temporarily gone and my ears rang for the entire next day. Maybe we stumbled on a temporary cure for Tinnitus ! wink.gif
Your ears have warned you it does not get better likely they are already permanently damaged you could likely incur additional hearing loss and pain from here forward if you do loud anything to much or maybe even occasionally without loud noise also but certainly with . it comes and goes occasionally with varying intensity but generally does not get better.
Ever heard the expression no highs no lows must be Bose ............... it isn't always the Bose. FWIW that's where you may be headed just saying.
take care.
tubetwister is offline
Old 10-14-2013, 04:35 PM
A9X-308's Avatar
Quoted: 1302 Post(s)
Liked: 965
Originally Posted by tubetwister View Post
@ A9X-308
Thanks for the reply:
My pleasure.
As I presently understand your reply I can safely assume at least in this case if the specs were true a 200WPC amp would not be unreasonable even if the average
music level was 2WPC and the 200wpc spec would easily accomodate a momentary 20dB program peak without distressing the amp and speaker
am I good with that line of thinking ?
You'd be spot on.
That would be my guess looking at them without having heard them .
I like corner horns and la scalas though .
best regards
I've owned Khorns, La Scalas and Heresys. Not bad but can easily be bettered.
A9X-308 is offline
Old 10-14-2013, 05:21 PM
Liked: 622
Originally Posted by A9X-308 View Post
My pleasure.
You'd be spot on.
For sure with modern speakers some with and some without subs the possibilities are endless .
