AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (http://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   What is a Good Book on High End Audio? (http://www.avsforum.com/forum/91-audio-theory-setup-chat/1494520-what-good-book-high-end-audio.html)
grigorianvlad 10-11-2013 02:57 PM
What makes a good objective reading on high end audio gear and/or HT? Not talking about periodicals or marketing and advertisement, but rather unbiased detailed explanation of the basics. My setup is hardly high end, but I think all gear obeys the same laws of physics.
Here is one that I found on Amazon.
Is it any good? Is there anything better? If so, how this other book is better?
Looking for a post 2010 release (in case there are new laws of physics discovered in the past 2-3 years)!
Appreciate your help.
grigorianvlad 10-11-2013 03:08 PM
I downloaded from P2P a PDF copy of the book while Amazon ships the paperback, but it has two minor defects. No, it is not worn out. As soon as I downloaded it, I discovered it was in Russian. The second drawback that the illustrations very much resemble those from "the Cat in the Hat".
Judge for yourself.
The wrong language isn't a problem (I can read Russian just fine). But these drawings! Jeez.. I got what I paid for.
mcnarus 10-11-2013 03:40 PM
Pure pseudoscientific crap. If you read it, you will become stupid.
grigorianvlad 10-11-2013 03:45 PM
In my case "more stupid" would have been appropriate.
On a more serious note, what is wrong with it? Where it does not deliver? What is an alternative?
mcnarus 10-11-2013 03:54 PM
But don't take my word for it. Download this:
http://www.theaudiocritic.com/back_issues/The_Audio_Critic_24_r.pdf
and turn to the review that begins on page 82. The review is written by this guy:
http://www.hofstra.edu/academics/Colleges/HCLAS/ENGNR/engnr_advboard_rich.html
A9X-308 10-11-2013 04:06 PM
Try Ethan's book.
lovinthehd 10-11-2013 04:13 PM
Just started this one myself http://www.amazon.com/Sound-Reproduction-Acoustics-Psychoacoustics-Loudspeakers/dp/0240520092
A9X-308 10-11-2013 04:32 PM
^^ I was just coming back to add in as well. Good book.
JorgeLopez11 10-11-2013 05:00 PM
I don't like guys that have studied hard and have impeccable technical credentials... :p
mcnarus 10-11-2013 06:34 PM
Nobody does.
But the b*st*rds are usually right.
lovinthehd 10-11-2013 06:44 PM
Nobody does.
Yes, usually reviewers from magazines existing to sell audio products and their successful salees are more believable. rolleyes.gif
Kevin Haskins 10-11-2013 07:54 PM
Floyd's book....
Ethan Winer 10-12-2013 11:18 AM
Originally Posted by A9X-308 View Post
Try Ethan's book.
Thanks for the plug. Judging from the tone of the OP's query my book probably is closest to what he's looking for. Though Floyd Toole's book is very good too for objective information.
--Ethan
grigorianvlad 10-12-2013 05:26 PM
--Ethan
Thanks, everybody. All 3 books are on my reading list now.
krabapple 10-14-2013 11:32 AM
Damn, whatever happened to David Rich? His articles were great...he wasn't afraid to open up hardware and tear into the guts.
(later), ah I see he's still at it... hurrah!
http://www.hometheaterhifi.com/technical-articles-and-editorials/technical-articles-and-editorials/options-by-supplier-and-price.html
grigorianvlad 10-14-2013 12:32 PM
Thanks a lot! I started the first book, but I dont think any of them go in-depth on AVR architecture. This is great!
grigorianvlad 10-14-2013 06:43 PM
I am on "Biwired Speaker Connections" part of Complete Guide to High End Audio. I find it rather confusing.
In a bi-wired system, the power amplifier “sees” a higher impedance on the tweeter cable at low frequencies, and a lower impedance at high frequencies. The opposite is true in the woofer-half of the bi-wired pair. This causes the signal to be split up, with high frequencies traveling mostly in the pair driving the loudspeaker’s tweeter circuit and low frequencies conducted by the pair connected to the loudspeaker’s woofer circuit. This frequency splitting reportedly reduces magnetic interactions in the cable, resulting in better sound. The large magnetic fields set up around the conductors by low-frequency energy can’t affect the transfer of treble energy. No one knows exactly how or why bi-wiring works, but on nearly all loudspeakers with bi-wiring provision, it makes a big improvement in the sound.
How are the signals split? This is biwiring. Two banana plugs (+ & -) at the amp end, four at speaker posts. It is basically THE SAME WIRE with different number of connections. Also, I tried bi-amping (which is supposed to be more effective than biwiring) and did not hear any difference at all. Granted, I did not use two separate amps for highs and lows - just my AVR allows rear surrounds to be converted for biamping, but still...
So, two questions:
1) Is biwiring really effective and I mean an audible difference however indiscernible?
2) If it is - how does single wire with different plugs at the end does this?
lovinthehd 10-14-2013 06:55 PM
Bi-wiring is great if you're selling speaker wire, waste of wire otherwise.
sdurani 10-14-2013 07:04 PM
Originally Posted by lovinthehd View Post
Bi-wiring is great if you're selling speaker wire...
Which is how it got the nick-name "buy-wire".
grigorianvlad 10-14-2013 07:11 PM
Yeah, I understand, but I am trying to understand this logic behind "isolated bass and treble sections" in the pic above. How are they isolated? The amp output is just one post. Does the wire do isolation by itself? There has to be some logic behind this statement, however flawed. Is there?
lovinthehd 10-14-2013 07:23 PM
It's called bullsh*t.
sdurani 10-14-2013 07:23 PM
Technically it isn't the wire that does the isolation but the signal itself that makes the decision: i.e., even though all the frequencies start out at the same binding posts, when they reach a fork in the speaker cable, the higher frequencies choose one pair of wires while the lower frequencies (knowing that one pair of wires is already taken) travel along the other pair of wires.
mcnarus 10-14-2013 07:26 PM
No, there is no logic to it whatsoever. The only point is to try to get you to spend more $$$ on wires. As I told you already (see post #3), Harley is a fraud who does not know what he is talking about. Read the book review I linked to in post #5 for more evidence of this.
grigorianvlad 10-14-2013 07:30 PM
I think this is exactly what the book says, but how? How does this decision making process works? I don't think the wire is remotely capable of "knowing"! There is some sort of a law of physics or math formula there. I would be able to understand it if there was one, but I just I want to know if it does exist.
Let's say the author implies "if you have a source clear enough, amp good enough and speakers sophisticated and dynamic enough then biwiring ..." and so on. I understand it wouldn't make a difference for me with my equipment, but I want to understand the best case scenario.
lovinthehd 10-14-2013 07:36 PM
Dude, it's a sales pitch. There is no science. It's just for gullible consumers.
mcnarus 10-14-2013 07:38 PM
There is no best-case scenario. That's bulls**t, too. If a change in wiring has an audible effect (which can happen, in extreme circumstances), it wouldn't take particularly great equipment to hear it. As long as your speakers cover the frequency range where the audible effect occurs, you'll hear it.
sdurani 10-14-2013 07:40 PM
Of course the wire isn't capable of "knowing". It's just a piece of metal, providing a pathway. Like I said, it is the signal that knows which pair of wires to travel down.
lovinthehd 10-14-2013 07:41 PM
More required reading when it comes to wire if you haven't already seen this http://www.roger-russell.com/wire/wire.htm#connect
grigorianvlad 10-14-2013 07:42 PM
All right, it is nonsense then. Moving on. Thanks for the help, guys.
kiwi2 10-14-2013 07:49 PM
It's the current draw that flows separately in each cable. Bi-wiring should be two sets of complete individual cables all the way between the amp and speaker.
Whether or not it makes a difference is debatable.
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
