HDD Phone Receiver....Is it possible!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-12-2013, 09:39 AM - Thread Starter
live4rush's Avatar
Hello guys,
I want to be able to access music/video on my external hdd via phone (to navigate) and play it through my receiver.
Wat is a good way to do this or is it even possible?
External HDD -->something --> Phone(To Navigate) --> Receiver --> Speakers
What is that something???
I am not looking for home server suggestions please.
live4rush is offline
post #2 of 6 Old 10-12-2013, 10:14 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
There are a few ways to do this these days. But first of all, what kind of phone are you using?
What I would do is have an external storage (NAS, external hdd) connected to a computer on your network or directly attached to a media device that supports external storage. Lots of gear does this now. Then you can interface with this storage on your phone in one way but an explanation of that would depend on what phone and OS you're using. More on that later. Then you can pick up a Bluetooth adapter for your AVR or attached media device if it has that capability. Your phone would use your home Wi-Fi to stream your music from your home network and onto your phone. Then the bluetooth is used to send it right back to your audio system.
That's it pretty much. Wireless digital sound from your phone. A more thorough explanation of all this can be had once we know what kind of capabilities your phone has. wink.gif
You could eliminate the whole phone and bluetooth bit by using a modern AVR (if youre using one) and just hook up an external hdd straight to the AVR. Most AVR's these days have the ability to stream music off your home network or from a direct usb connection. That way all you need is the remote from your AVR to control your music. In fact, most of these capable AVR's will have an onscreen interface for all the streamed content.
Scott Simonian is offline
post #3 of 6 Old 10-13-2013, 02:06 PM - Thread Starter
live4rush's Avatar
Thanks. I have both android and ios devices at home.
Can you give me a few examples of those modern receivers that are capable of playing directly from usb hard drive.
Presumably those receivers have app interfaces to use a controller to navigate.
post #4 of 6 Old 10-13-2013, 04:14 PM
Bass Enabler
Liked: 5025
Pretty much any AVR in the $500+ range that was made in the past two or three years. Look for a usb input and any mention of streaming capability. There are dozens upon dozens that can do it.
post #5 of 6 Old 10-30-2013, 11:27 AM - Thread Starter
live4rush's Avatar
Ok I found the answer by testing
Yes::
1. Any receiver with dlna capability can do this by connecting to a NAS box
2. You can used a phone app if available to control playback
No::
1. Just having a USB port in front/back of the receiver does not mean that it can read audio from a HDD
2. The USB port can read from mp3 players, flash drives and small HDDS that are FAT formatted.
3. NTFS formatted hard drives do not work usually
4. Highest denon receiver (4520ci) would not read from the HDD (NTFS) as well
post #6 of 6 Old 10-30-2013, 10:07 PM
Bass Enabler
Liked: 5025
Yup. Pretty much what I said.
Did you find an AVR that you like?
