Recommend me an SPL meter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-21-2013, 12:25 AM - Thread Starter
GotNoRice's Avatar
Quoted: 14 Post(s)
I already have one that has worked well enough, but I am looking for something more robust. My current meter maxes out at 130dB; I'd like something that went as high as perhaps 160dB
I need a meter that measures both A and C weighting.
GotNoRice is offline
post #2 of 5 Old 10-22-2013, 06:43 AM
PrimeTime's Avatar
Quoted: 535 Post(s)
Liked: 250
Sounds like you meant to post in Car Audio.
The old B&K's went up that high. 160dB is one acoustical watt per square centimeter (free field, not pressure chamber), if I recall. One usually only sees that inside crank-it-up cars, or compression-driver throats. The air itself is quite nonlinear (especially at higher frequencies) at these levels.
Glen B likes this.
PrimeTime is offline
post #3 of 5 Old 10-22-2013, 02:09 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1236
You do understand that selling a SPL meter that goes much beyond 130 dB SPL would be risking malpractice, because using it by holding it in a sound field can involve serious injury to the operator?
130 dB corresponds to the threshold of pain, according to many references. 140 dB can cause injury.
Glen B likes this.
arnyk is offline
post #4 of 5 Old 10-23-2013, 07:58 AM
DonH50's Avatar
Quoted: 1738 Post(s)
Liked: 1279
I thought 120 dB was ToP?
Most mics do not reach 160 dB... My earthworks M30 is rated to 142 dB and that is a fairly high-end measurement mic.
There's an iPhone app that claims 160 dB. A number of meters on the Davis website reach 140 dB.
As Arny said it is unlikely you'll find any sort of hand-held meter with that range. The ones I have seen that reach >140 dB typically use special mics and wire to a DMM or test instrument. They also cost thousands of dollars.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5 of 5 Old 10-24-2013, 04:25 PM - Thread Starter
GotNoRice's Avatar
Quoted: 14 Post(s)
My post has nothing to do with Car Audio, so I'm pretty sure I didn't mean to post there.
That isn't necessarily the case. One of the reasons I specified that I needed a meter that can measure both A and C weighting is because I typically measure using C weighting. The main difference being that C is much more sensitive to bass, whereas A tries to measure along a curve that is approximate to the most sensitive areas of human hearing. Most safety guidelines, etc are given using A weighting.
Human Hearing:
130dBA at ~4000hz, which is about the most sensitive frequency of human hearing, would result in almost instant hearing loss.
130dBC at ~50hz would be quite different. Measured using A weighting, you'd measure maybe 100dBA. Also, the human ear can sustain much higher SPL levels in the low frequencies compared to the speech frequencies before damage occurs.
