Audyssey XT32 help...im really scratching my head here - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-24-2013, 08:16 PM - Thread Starter
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
I only have two speakers running that are full range capable ( Polk rti12s )and set as large ( bi amped ) wtih all other speakers disabled. I assumed audyssey would let me adjust the lower end frequencies through its graphic EQ after running the software but it doesnt....
Does anybody know why Audyssey XT32 from a Denon X4000 only allows you adjust frequncies from 63 hz and up from its graphic eq?
To be honest, before I ran the setup, I was under the assumption that Audyssey XT32 with sub eq would produce a spl vs freq graph showing me my in room response and then through its software I would be able to adjust the peaks and nulls through the graphic eq....sorta like what an SMS sub equalizer does
What do I need to do here to accomplish that and how?
Im really a noob at this
music_to_my_ear is offline
post #2 of 6 Old 10-24-2013, 08:20 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
You should address your query in the appropriate thread http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1
lovinthehd is offline
post #3 of 6 Old 10-25-2013, 09:59 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I agree with lovinthehd - the thread he linked is the official audyssey thread.
I will add the answer to your Q is you need Audyssey Pro to actually dial/tweak your curve response.
Say $150 for lic and you need to "borrow" the mic kit or buy it for $450 approx
http://www.audyssey.com/technologies/multeq/multeq-pro
Custom Target Curves
With MultEQ Pro Software, Audyssey Installers can customize the Target Curves and finely tune the target sound to resolve the acoustical problems of each individual room.
mtbdudex is offline
post #4 of 6 Old 10-25-2013, 08:46 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 90
Ok so to tweak the audyssey curve I need to buy audyssey pro. Gotcha. I actually will really consider that. It isn't as expensive as I would've thought. Thanks guys! Thanks a bunch
post #5 of 6 Old 10-26-2013, 04:05 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Read this thread to help you, the "Pro" version
http://www.avsforum.com/t/1346723/the-audyssey-pro-installer-kit-thread-faq-in-post-1
mtbdudex is offline
post #6 of 6 Old 10-26-2013, 11:29 PM - Thread Starter
Quoted: 185 Post(s)
Liked: 90
Cool. Will do. Thanks man! Cheers
