Help with Speaker Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-26-2013, 01:03 AM - Thread Starter
mijotter's Avatar
Liked: 59
I am having a 7.1 surround set up. However, the back surrounds are giving me a little issue. I'm fairly limited to where I can place them. My only two options are having the speakers 18 1/4" apart or 29 1/4". Will this difference matter?
The 29 1/4" apart option puts the tweeters slightly more in line with the main seating head positions. But would require me overlapping a face plate on a light switch and an outlet.
Thank you.
mijotter is offline
post #2 of 10 Old 10-26-2013, 01:51 AM - Thread Starter
mijotter's Avatar
Liked: 59
Anyone?
mijotter is offline
post #3 of 10 Old 10-26-2013, 07:15 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Seems like they are too close together on your back wall.
What type of speaker are they?
Monopole, bipole, dipole?
Possible you should use just 1 for a 6.1 setup.
Also, you posted then wanted reply within 20 minutes......patience.
Via my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #4 of 10 Old 10-26-2013, 12:50 PM - Thread Starter
mijotter's Avatar
Liked: 59
It was closer to an hour but I just needed some advice from you guys sorry. I ended up flipping the speakers so they lay horizontal but the tweeters are on the opposite ends and directly in line with each persons listening position in the main seating area.
Hopefully having them horizontal isn't a bad thing. They are Infinity OWS-1's.
mijotter is offline
post #5 of 10 Old 10-26-2013, 03:53 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
actually it is, as your woofer/tweeter and it's crossover is designed with certain polar dispersion characteristics - both up/down and side-side, and by random flippin them you are defeating the speaker designer intent.....
Hence everyone also says for a center channel you NEVER flip a RH/LH main onto it's side......
mtbdudex is offline
post #6 of 10 Old 10-26-2013, 03:57 PM - Thread Starter
mijotter's Avatar
Liked: 59
What are the repercussions of a horizontal setup as far as sound to my ears is concerned? Will it sound muffled, unlocalized, etc?
Also, I noticed you're in SE MI. I lived in Adrian for quite a while
mijotter is offline
post #7 of 10 Old 10-26-2013, 04:00 PM
vm8444's Avatar
Can Inceiling be used here as rear two?
vm8444 is offline
post #8 of 10 Old 10-26-2013, 04:09 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Imagine this; you mids/hi freq are being dispersed in a designed pattern, sprayed out mostly side-side, and as you go up/down it tapers off.
s
so, when you turn your speakers sideways, you are having a central "hot" area directly forward of the speaker - on center....and inducing un-wanted reflections also off the ceiling/floor.....
So, with that image what do you think would happen as you move side-side off center of the speaker that is now sideways?
(if I tell you then you are not learning....)
mtbdudex is offline
post #9 of 10 Old 10-26-2013, 08:09 PM - Thread Starter
mijotter's Avatar
Liked: 59
Based on that image and your description, it would seem that there could potentially be some "dead spots" to the left and right of the speaker.
mijotter is offline
post #10 of 10 Old 10-26-2013, 08:45 PM
HopefulFred's Avatar
Quoted: 510 Post(s)
Liked: 453
...there could potentially be some "dead spots" to the left and right of the speaker.
That's well said. But also, the dead spots are only at certain frequencies - so instead of being quiet sounding, they are manifest as frequency-response anomalies - weird dips at some frequencies. And they're not just likely, they're virtually guaranteed.
HopefulFred is offline
