Amplifiers affecting speaker frequency response - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 362 Old 11-14-2013, 01:36 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by OllieS View Post
Originally Posted by amirm
I have the paper and read it a number of times. The paper is a "meta analysis" in that it presents no new research. But rather attempts to draw conclusions based on formal and informal tests done by others. This is from the intro of the paper:
Okay, so there is no in-depth information surrounding the testing itself, as in how the tests were conducted or any test protocols - only the results of the testing are known and published.
Would you say that is sufficient to draw a conclusion of global significance?
It is only necessary to go into all of the details about how each test was done if every test was done in a different way. These tests were all level-matched, time-synched, quick-switched under listener control, ABX tests.
arnyk is offline
post #182 of 362 Old 11-14-2013, 01:42 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
It is great that you have done your own testing. But as far as I know, Arny does not at all value single blind tests. So if you agree with him, you need to dismiss the results of your own tests .
Um, no. Single-blind tests that produce positive results are open to the criticism that the administrator(s) inadvertently tipped off the subject(s). But single-blind tests with negative results do not suffer the same flaw.
Lest you think that unfair, it works in the other direction, too. A negative test that didn't allow quick switching is open to the criticism that better test protocol might have produced a different result. But if you can hear a difference reliably without quick switching, you will certainly be able to with it.
MarkHotchkiss likes this.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #183 of 362 Old 11-14-2013, 01:44 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
You sent me an AES link. What am I supposed to do with that?
Click on it.
Sheesh.
mcnarus is offline
post #184 of 362 Old 11-14-2013, 01:48 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Originally Posted by amirm View Post
Originally Posted by 67jason View Post
When first learned about the concepts being discussed here I was unsure of their validity and correctness. You know what I did? I spent hours upon hours researching abx, ab, and dbt tests, both audio related and otherwise. I learned a lot. I then, to the best of my ability performed my single blind test in my own home using a respected stereo receiver, 2 respected avr's and a respected power amp. All using the same source and material, level matched to the best of my ability. Ya know what I discovered? Yup that's right, these guys here like arnyk, kbarnes, and dozens of others were right.
It is great that you have done your own testing. But as far as I know, Arny does not at all value single blind tests. So if you agree with him, you need to dismiss the results of your own tests smile.gif. If you do believe in value of single blind tests, there are indeed formal ones that dispute the position of the people you list. That data has been presented in this forum numerous times. Surprised that your research did not land on them.
I also see nothing in your research with regards to what we are asking the opposition to do: read AES articles. How many articles did you buy and read there?
I'm well aware of where single blind tests fall into the scheme of things. I don't need you to educate me on the fact that arnyk has issues with them, nor that they are not the absolute best methodology to use. I did the best that I could with my own resources. My results were my own and were enough to satisfy my need to know weather or not the concepts as ofteoften discussed on avs, of what can and what can't constitute an audible difference amongs receiver, amps and avrs, as well as sources such as shiny disc players.
What does it matter how many papers I got from aes? Is it an ego thing? The more I obtained the more credible I am? Is that it?
I am very familiar with you posting style and how you don't take well to being wrong and how you will nitpick the minutiae in all posts you dont like, as well as your need to continue to drag out arguments. Feel free to pick my posts and my conclusions apart if you wish, it won't change the laws of physics, nor will it change what I have learned for myself to this point, nor what I may continue to learn in the future.
The fact of the matter is I took the time to research and learned a thing or two in the process and will continue to do so.
kbarnes701 likes this.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #185 of 362 Old 11-14-2013, 01:59 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
By the way, Ollie, Mr. Barnes provided a link to a specific ABX test of amps. Here it is again:
http://webpages.charter.net/fryguy/Amp_Sound.pdf
This is one of the specific reports that were summarized in the AES paper, so you can see how these tests are typically done. Not every test report is going to be found on the Web. But in my experience, this is a pretty good example of the whole process.
mcnarus is offline
post #186 of 362 Old 11-14-2013, 02:52 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Besides building some of the ABX equipment used, I was also a listener in that test, if memory serves. The article is a good reflection of what actually happened and also is a good practical example of ABX testing. There was a corresponding test involving the same people and CD players. CD players with live switching is very hard. Amps are easy.
arnyk is offline
post #187 of 362 Old 11-14-2013, 03:15 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
Please don't take this personally but yes, it absolutely means you have no credibility in this argument. You cannot ask the other to read AES reports which you yourself have not found worthy to read. There is incredible amount of knowledge and data in conference/journal papers that routinely disputes what the vocal majority thinks in this forum. Not having read it, you will equate what makes sense to your gut as the truth. And that gut feeling may very well be wrong.
I realize it is outside of the means of many to perform such research. Given that, perhaps it is better to not be so confrontational on the topic. Because the arrow can on a dime turn toward you as it did in this interchange smile.gif.
amirm is offline
post #188 of 362 Old 11-14-2013, 03:37 PM
diomania's Avatar
Liked: 50
Isn't it worse for someone who's read those AES papers to say, "As unfair as it might be, I am going to punt that question." to a question if jitter difference between S/PDIF and HDMI is audible?
diomania is offline
post #189 of 362 Old 11-14-2013, 03:58 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Boy, that escalated quickly!
http://www.youtube.com/watch?v=Uh7tgX_Uaqs
I stabbed a man in the heart.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #190 of 362 Old 11-14-2013, 04:48 PM
amirm's Avatar
Liked: 739
I answered that question in a follow up article I wrote for Widescreen Review Magazine 6 or so months ago. Have not had time to put it in our online library so you have to buy the back issue to read it. Here is a picture of the measurement setup and equipment I tested for that article:
It is the most extensive and up to date analysis of HDMI and S/PDIF anywhere.
amirm is offline
post #191 of 362 Old 11-14-2013, 04:57 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
^Somebody's ego isn't fitting on my screen. Looks like I need a bigger monitor. rolleyes.gif
"...the most extensive and up to date analysis of HDMI and S/PDIF anywhere?" Uhm, anywhere? So I guess large companies that produce consumer A/V products never do any such testing.
Your picture just looks like a couple of stacks of overpriced gear alongside an old analog oscilloscope and a lower-cost (relatively speaking) Audio Precision.
beaveav is offline
post #192 of 362 Old 11-15-2013, 01:05 AM - Thread Starter
Shaun B's Avatar
Quote: arnyk
And just for grins, compare these two pages:
I did. But you linked me to two AVR tests. I was hoping to see separate components compared against the receiver.
Shaun B is offline
post #193 of 362 Old 11-15-2013, 03:43 AM - Thread Starter
Shaun B's Avatar
Peak power numbers tend to be short bursts in the audio world. An amp with a very stiff supply has essentially no headroom, so a 50 W amp with say 60 Vpp power rails will deliver very little more than the rated 50 W before clipping.
Why would a stiff supply result in no headroom? Just asking, not trying to argue,.
Shaun B is offline
post #194 of 362 Old 11-15-2013, 05:24 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Good question. I think that the answer lies in how you define headroom. There are several relevant definitions:
(1) Headroom - defined as the difference between the maximum power that is available from the amp, and the amount that you ever actually use. I would call this local headroom because it relates to the specific system and user.
(2) Headroom or "Dynamic headroom" defined as the difference between the amp's maximum power output with a long-term steady state sine wave output (probably best called static maximum output or steady-state maximum outputs), versus the power available in short bursts (best called dynamic maximum or peak output). This is a global number because it can be measured on a test bench and is the same as long as it is measured under the same standardized conditions.
Amps with stiff power supplies tend to have the same long-term steady state output and short-term dynamic or peak output. In that sense they have no headroom.
arnyk is offline
post #195 of 362 Old 11-15-2013, 05:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
I provided you with links to two AVRs - one mid-fi and one high end. BTW have you ever done your own research in areas like this? I'd rather teach you to fish than keep giving you dead fish. ;-)
arnyk is offline
post #196 of 362 Old 11-15-2013, 05:37 AM - Thread Starter
Shaun B's Avatar
Yeah I know, but I thought the idea was comparing AVR's to separates. I thought that is what you set out to prove, that AVR's measure the same or better than high priced separates.
Shaun B is offline
post #197 of 362 Old 11-15-2013, 05:42 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
+1
Amir's incessant baiting with these hyperbolic descriptions of alleged secret tests could be irritating given all of the questionable claims he previously made for week after week about how everybody with an AVR needs to run right out and buy an asynch USB DAC because of the high audible jitter he alleged was hiding in their AVR's HDMI inputs. The advice was largely irrelevant because most audiophiles drive their AVRs with cable boxes, stand-alone digital music players and blu ray players, not PCs or other devices with USB outputs.
There seem to be precious few common audiopile sources that even have USB outputs.
Amir has sort of left us hanging twice, once after he failed to show that HDMI jtter was actually audible, and again after he failed to show us any relevant way to circumvent it, perchance the audible jitter existed in the first place. This is compounded by the fact that he staked his reputation on a few technical tests that are now relevant to just a few AVRs, many of which have been subsequently replaced in the marketplace, and whose publisher seems to have abandoned doing that kind of testing.
arnyk is offline
post #198 of 362 Old 11-15-2013, 05:51 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
yeah....
no worries, I aint the least bit concerned on your views of my credibility. wink.gif
MarkHotchkiss, FMW and kbarnes701 like this.
67jason is offline
post #199 of 362 Old 11-15-2013, 05:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
I did show that by showing high priced separates that were electronically the same as lower priced AVRs with features removed.
But, I'll go the extra mile:
http://www.soundandvision.com/content/linn-chakra-c2200-and-c3200-amplifiers-ht-labs-measures
Linn Chakra C3200 Amplifier, $5,400
"Both channels driven continuously into 8-ohm loads:
0.1% distortion at 105.8 watts
1% distortion at 125.6 watts"
http://www.soundandvision.com/content/pioneer-vsx-1123-av-receiver-ht-labs-measures
" Pioneer VSX 1123 Price $600"
"Two channels driven continuously into 8-ohm loads:
0.1% distortion at 127.7 watts
1% distortion at 146.2 watts"
arnyk is offline
post #200 of 362 Old 11-15-2013, 06:19 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5073
Originally Posted by kbarnes701
I can understand that you only have a scant understanding of science, but surely you are able to use Google?
Could you be any more cryptic?
So what did you get from reading the articles?
kbarnes701 is offline
post #201 of 362 Old 11-15-2013, 07:43 AM
DonH50's Avatar
Quoted: 1827 Post(s)
Liked: 1359
See Arny's response in post 194. The second explanation is my rationale as it relates to amplifier specifications. The practical examples are an amp with very limited power supply that can only provide full voltage and current briefly before the rails sag and thus the steady-state (long-term, FTC) power rating is much lower than the "dynamic" power available for brief transients. At the other end is an amp with a regulated power supply that provides essentially the same voltage no matter the load; dynamic headroom relative to the steady-state spec is essentally zero.
There are been very good amplifiers designed with either philosophy. Krell and some other amps use(d) regulated supplies and have ~0 dB dynamic headroom over spec. Bryston and some others were (in the past, have not looked recently) actually rated with 6 dB dynamic power.
I do not like "dynamic power" as a spec because parameters such as how much power for how long are rarely specified.
What Arny calls "local headroom" is that provided in normal operation, the power available from the amp beyond what you are using on average at your listening levels. That is clearly related to the steady-state and dynamic power ratings of the amp, but I was referring to headroom relative to the amp's specifed output ratings.
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #202 of 362 Old 11-15-2013, 07:58 AM
OllieS's Avatar
Thank you for providing these links! Interesting results given the price differences.
OllieS is offline
post #203 of 362 Old 11-15-2013, 08:02 AM
OllieS's Avatar
So I see the Pioneer has a higher power output into 8 ohms but the Linn Chakra has almost double the power into 4 ohms! Also the Pioneer has a higher signal to noise ratio? The only thing the Pioneer test results do not indicate are the THD+N result. On the Linn it's 0.006%.
OllieS is offline
post #204 of 362 Old 11-15-2013, 08:24 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
You seem to be making facts up:
Pioneer: "Into 4 ohms the amplifier reaches 0.1 percent distortion at 129.1 watts and 1 percent distortion at 165.7 watts."
Pioneer test result with THD+N specified, not absent as you seem to be claiming
Linn: " Into 4 ohms, the amplifier reaches 0.1 percent distortion at 197.3 watts and 1 percent distortion at 221.5 watts"
197 watts is only about 50% more than 129 watts, not twice as you are misleadingly claiming.
Note that 50% more power is less than a 2 dB difference. Run the volume on your AVR up or down by 4 clicks and tell me if you think that it is worth the difference in price. ;-)
Also note that the Pioneer is a true 7.1 multichannel AVR while the far more expensive Linns are only 2-3 channels.
arnyk is offline
post #205 of 362 Old 11-15-2013, 10:02 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1686
Just look at the specifications for any two amps and compare them. Audibility begins when distortion is at 1% or higher and when frequency response measures 3 db from flat. What you will find is that all of them have inaudible distortion and inaudible variance from a flat frequency response. If you want to do some blind testing yourself, knock your socks off. Most of us have already done it and have shared our experience.
FMW is offline
post #206 of 362 Old 11-15-2013, 10:25 AM - Thread Starter
Shaun B's Avatar
How would I go about doing such a test? Can I do it at home?
Shaun B is offline
post #207 of 362 Old 11-15-2013, 10:29 AM - Thread Starter
Shaun B's Avatar
What is the crosstalk figure? I see the more expensive processor has a much lower crosstalk compared to the Pioneer.
Shaun B is offline
post #208 of 362 Old 11-15-2013, 11:52 AM
DonH50's Avatar
Liked: 1359
Crosstalk is how much signal from one channel appears in the other channel. In the real world the spec is essentially insignificant past maybe -60 dB; probably below -40 dB does not matter given typical mixes and systems. At -80 dB or so, the Pioneer spec, if you had one speaker sending out a signal of 100 W (very loud), the second speaker would be receiving 1 uW (10^-6 W) from crosstalk. Good luck hearing that, especially if anything is going on (i.e. any sort of signal) in the other speaker.
DonH50 is offline
post #209 of 362 Old 11-15-2013, 12:02 PM
amirm's Avatar
Liked: 739
THD figure is an improper metric for audibility of distortion. It does not at all follow the rules of psychoacoustics. If I have a 5 Khz signal with a second harmonic at 10 Khz vs a 1 Khz signal with second harmonic at 2 Khz at the same level, the THD will be the same (with respect to the second harmonic). Audibility of these two situations however is very different due to frequency masking and resolution of auditory filters. One must know the spectrum of the harmonic distortions to determine the audibility which of course is never given (or often not measured individually).
We use THD because it used to be easy to measure and has become so ingrained in the industry that it continues to be used. But other than a gross measure, it has little value.
amirm is offline
post #210 of 362 Old 11-15-2013, 12:39 PM
diomania's Avatar
Liked: 50
Or you could just answer that here now, no?
Online library, you mean your electronics dealer website?
diomania is offline
