my projector got only headphone jack output, can i connect it to my home theater system ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-11-2013, 02:40 AM - Thread Starter
Alghaith's Avatar
hello, i just ordered  ViewSonic PJD7820HD and it only got headphone jack audio output. how can i connect it to my home theater ? can i get 5.1 with the 3.5 headphone jack ? thanks .
Alghaith is offline
post #2 of 14 Old 11-11-2013, 04:26 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Usually sound completely bypasses the projector. However the headphone jack could drive a home audio system via one of its aux inputs.
arnyk is offline
post #3 of 14 Old 11-11-2013, 11:22 PM - Thread Starter
Alghaith's Avatar
Alghaith is offline
post #4 of 14 Old 11-12-2013, 12:12 PM
Alan P's Avatar
Quoted: 4695 Post(s)
Liked: 3321
You can NOT get 5.1 from a headphone jack without matrixing.
Do you not have a sound system? What video source are you using to feed the projector?
Alan P is offline
post #5 of 14 Old 11-12-2013, 12:28 PM - Thread Starter
Alghaith's Avatar
How do I do the matrixing?
Im gonna use ps3 HDMI . My sound system is samsung.
http://m.samsung.com/ae/consumer/tv-audio-video/home-theatre/home-theatre-system/HT-C330/MEA
Alghaith is offline
post #6 of 14 Old 11-12-2013, 12:29 PM - Thread Starter
Alghaith's Avatar
Alghaith is offline
post #7 of 14 Old 11-12-2013, 01:04 PM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
If using a "headphone" output, you'll be limited to Dolby Pro-logic for "surround sound".
EDIT:
You may be able to run an optical (Toslink) cable from the the PS3 directly to the HTS for Dolby Digital.
Ratman is online now
post #8 of 14 Old 11-12-2013, 01:05 PM
Alan P's Avatar
Liked: 3321
Well, according to the link for your sound system, it has one HDMI in connection - you would hook your PS3 via HDMI to your sound system and HDMI out from your sound system to your projector. No need to use the headphone jack.
Alan P is offline
post #9 of 14 Old 11-12-2013, 02:34 PM
Ratman's Avatar
Liked: 1024
Well, take a better look at the specs. No HDMI in or out on the HT-C330. wink.gif
HDMI Out No
Composite Output Yes
Component Output Yes
SCART Out No
HDMI Input 0
post #10 of 14 Old 11-12-2013, 02:39 PM
Alan P's Avatar
Liked: 3321
HDMI Out No
SCART Out No
HDMI Input 0
Alan P is offline
post #11 of 14 Old 11-12-2013, 02:40 PM
Alan P's Avatar
Liked: 3321
Or, if the projector has component in and the OP has the multi out cables for the PS3......
Alan P is offline
post #12 of 14 Old 11-12-2013, 03:18 PM
Ratman's Avatar
Liked: 1024
Try the optical cable as suggested.
post #13 of 14 Old 11-13-2013, 03:03 AM - Thread Starter
Alghaith's Avatar
unfortuntly theres no optical in the projector :/
i will try that when the projector  arrive, im thinking of return it and get LG PA75U but that will take a long time since im ordering from Amazon (US) and im in Kuwait .
this is a free receiver actually and its new in box :p when i bout my tv, the thing is i have my main setup in the living room (Onkyo HT-S9300THX) + (Samsung ES8000) ,  i got a new garden roof and i wanted to buy a projector since i have another HT system . now im searching for projector screen and its too expensive  here :| .
can i use this splitter on the projector to connect it to the HT AUX ? can i get Dolby Pro-logic ll ?
thanks all for your responds :)
Alghaith is offline
post #14 of 14 Old 11-13-2013, 06:51 AM
Ratman's Avatar
Liked: 1024
Yes I know! That's why I suggested in post #7 to run the optical directly from the PS3 to the audio system for Dolby Digital!
If you decide to use the analog audio output from the projector to the audio system, you need a "stereo" adapter or cable similar to this:
http://www.monoprice.com/Product?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
