How to determine which DAC to purchase. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-11-2013, 01:03 PM - Thread Starter
avsform1's Avatar
Quoted: 30 Post(s)
Liked: 30
In the search of into getting cleaner sound, I looking at purchasing a DAC. Where can I research on what makse a DAC a good DAC. Why buy a DAC when the receiver has Burr Brown DAC?
avsform1 is offline
post #2 of 4 Old 11-11-2013, 01:16 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
You are barking up the wrong tree. An outboard DAC will not give you cleaner sound, or improve your system in any way you can hear. The Burr-Brown (or whatever it is) in your receiver is all you need.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 4 Old 11-11-2013, 01:21 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1240
This is a good thing to look into for at least 10 seconds, and then realize that it is futile. ;-)
It's not that the AVR has a Burr Brown DAC, because Burr Brown is just one of several makers of good DACs. Just about everybody who makes good DACs makes a few that are dirt cheap and work and that's about it. They still aren't that bad, So, don't judge DACs by brand name.
I think that when you buy an AVR you should look at the performance of the whole thing, and not the individual tiny little parts inside.
If you are interested in cleaner sound, things like loudspeakers and room acoustics vary more and make a bigger difference.
arnyk is offline
post #4 of 4 Old 11-12-2013, 11:09 AM
Ethan Winer's Avatar
Quoted: 265 Post(s)
Liked: 359
This.
Ethan Winer is offline
