Live Audio Recording Input Only Produces Static - AVS Forum | Home Theater Discussions And Reviews
Old 11-16-2013, 12:57 AM - Thread Starter
ptto911's Avatar
Hello,
I went to film a musical today with the Broadcasting team at my school, and I got the audio feed from the mixing board via XLR. So I plugged the XLR into my audio interface to record it to my PC and all that came out was static. Once I got everything plugged in, the show already started, so I couldn't troubleshoot much with the sound engineer. It could not have been a computer or software issue either, since I was monitoring the audio interface's audio directly from the interface with headphones.
I searched online everywhere, but I couldn't really figure out why the whole signal was just static. If I turned phantom power off for the input, it was static. If I turned it on, it was a distorted clipping sound. But no actual sound that should have been recorded was being picked up.
Any help would be appreciated. Thanks!
ptto911 is offline
Old 11-16-2013, 03:54 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by ptto911 View Post
Hello,
Most engineers who provide a feed for visiting recordists, provide a line-level feed. Sounds like you were using the mic input of your audio interface, which can be way to sensitive and could easily be distorted.
arnyk is offline
Old 11-16-2013, 04:05 AM - Thread Starter
ptto911's Avatar
I can see how that could be true, however, my audio interface has a knob to adjust input sensitivity, and even with it nearly all the way down, it produced the same static sound. I am using the Roland Cakewalk UA-25EX interface, by the way.
ptto911 is offline
Old 11-16-2013, 01:54 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Ptto,
. . . and I got the audio feed from the mixing board via XLR.
Just a thought:
Did he give you a single XLR cable? Could it have been an AES/EBU digital-stereo signal instead of a balanced mono-analog signal?
MarkHotchkiss is offline
Old 11-16-2013, 02:18 PM - Thread Starter
ptto911's Avatar
Originally Posted by MarkHotchkiss View Post
Hi Ptto,
Just a thought:
Yes, it was one single XLR cable. He told me the signal would be in mono, and I had my interface set accordingly.
ptto911 is offline
Old 11-16-2013, 05:32 PM
Gizmologist's Avatar
Liked: 31
If it was a broadcast style mix desk the feed you got was likely a very high level signal along the lines of +4 db or higher and you system was just way over driven.
Gizmologist is offline
