So I got some old Soviet speakers. - AVS Forum | Home Theater Discussions And Reviews
Old 11-17-2013, 02:47 PM - Thread Starter
MrLatvian's Avatar
Hello!
Yesterday I got my hands on some old Soviet speakers , 2 to be precise. I'm not an audio guru, actually I know nothing about these sort of things...
I would love to connect both of them to my PC or TV. How could I do that? What hardware do I need?
Kriss
MrLatvian is offline
Old 11-18-2013, 02:41 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
Well, the first thing you would need is some sort of amplification (I'm assuming these 'old soviet speakers' are not powered) - i.e. a stereo amplifier or receiver.
It would also be good to know the resistance of the speakers. Do you know their ohm rating? How about sensitivity? What type of connectors do they have in the back?
Alan P is offline
Old 11-19-2013, 12:14 AM
kckun's Avatar
maybe would you take a photo of the back of those soviet speakers?
kckun is offline
Old 11-19-2013, 10:50 PM - Thread Starter
MrLatvian's Avatar
From what I could understand is that the resistance is 4 Oms
Regarding the sensitivity - how is that measured?
Here are all of the images I took. Hopefully that provides some info.
Old 11-20-2013, 04:21 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 3969
Cool! Just curious, how many speakers and what size? What year? From the graph, is looks to me that the speakers emphasize freqs above 750hz or so. Or de-emphasize freqs below 750hz.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Old 11-21-2013, 08:34 AM - Thread Starter
MrLatvian's Avatar
larry
Hey Larry!
I got 2 of them. The size is 4,5 inches. I did some research and it looks like they could be from the 80s-90s..
I even found a decent quality photo of them how they should have looked at their prime
Some added info about them: I confirmed that the resistance is 4 Ohms and "normal" power is 6 W (whatever that means) and the freqs are 80 Hz - 12,5 kHz
Old 11-21-2013, 01:08 PM
Ratman's Avatar
Quoted: 1284 Post(s)
Liked: 1028
Originally Posted by MrLatvian View Post
... and "normal" power is 6 W (whatever that means) ...
Either misread or mistranslated. It's probably "nominal".
Ratman is online now
Old 11-21-2013, 01:14 PM - Thread Starter
MrLatvian's Avatar
So yeah, back to the question - how powerful Amp would I need? Or does the Wats per line only determine the loudness of the speaker itself?
Old 11-21-2013, 01:25 PM
Ratman's Avatar
Liked: 1028
Old 11-22-2013, 09:33 AM
kckun's Avatar
It is the power required to power the speaker. You can use a lower powered amplifier but only when played quietly . You can use a higher powered one, say 100W but just don't turn the volume too high.
Usually Solid State amps have higher power ratings. There are many tube amps rated below 10W though.
MrLatvian likes this.
kckun is offline
