I could use some advice on a pair a Klipsch RB 61 I recently picked up - AVS Forum | Home Theater Discussions And Reviews
Old 11-17-2013, 05:29 PM - Thread Starter
busb0y's Avatar
The person who i purchased them from had them bi-amped, and removed the plate from the back and no longer had it. Can i just run speaker cable between the hi and low posts to accomplish the same thing? If i do so is there a particular gauge of wire I should use?
Thanks to everyone here as always!
busb0y is offline
Old 11-17-2013, 06:15 PM
Colm's Avatar
Liked: 94
Yes, you can use speaker cable. Whatever gauge you have on hand will do.
busb0y likes this.
Colm is offline
Old 11-17-2013, 07:37 PM - Thread Starter
busb0y's Avatar
Thank you sir.
busb0y is offline
Klipsch Rb 61 Ii Reference Series Bookshelf Loudspeakers Cherry
