HK AVR 235: Crossover Adjustment Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-27-2013, 10:43 AM - Thread Starter
HIDEF2013's Avatar
hello,
i am a noobie and am looking for your help. i want to adjust my crossover and i hit a road block. to see the crossover adjustments on my tv, the manual says to connect the avr to my tv via an s video cable. however, my new vizio tv does not have an s video connection. my avr is about 7 years old and does not have hdmi connections. any suggestions? thanks.
HIDEF2013 is offline
post #2 of 6 Old 11-27-2013, 11:35 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
Get a new receiver?
FMW is offline
post #3 of 6 Old 11-27-2013, 11:49 AM
sivadselim's Avatar
Quoted: 267 Post(s)
Liked: 224
Your AVR should have a composite video output (just a single RCA output; usually yellow) and it should pass the OSD through that, too. Does your Vizio have a composite video input?
It is possible, too, that your AVR passes the OSD via its component video outputs (if so equipped, they're 3 video outputs colored blue, green, and red) although many don't. Does your Vizio have component video inputs.
How have you adjusted all your other settings with no OSD?
(OSD = on screen display)
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #4 of 6 Old 11-27-2013, 01:35 PM - Thread Starter
HIDEF2013's Avatar
thanks for the reply. i will look into your suggestions. i have not adjusted anything yet.
post #5 of 6 Old 11-29-2013, 04:47 AM
BruceD's Avatar
Quoted: 12 Post(s)
Liked: 30
I have an older AV Preamp, a Proceed AVP2, with the same limitations, and I use a small 13" CRT I've had for many years and that you might be able to find used for almost nothing in a Goodwill store that has a composite video rca input. My Proceed AVP2doesn't output OSD on the component video output (red, green, blue rca).
In my case I also use an RF converter to take the composite video output signal from the AVP2 (rca cable) and convert it to a F-type cable input for the TV (my 13" TV only has a single F-type input ).
Siva's response is good advice.
BruceD
BruceD is offline
post #6 of 6 Old 11-29-2013, 09:02 AM - Thread Starter
HIDEF2013's Avatar
Harman Kardon Avr 235 7 1 Channel Audio Video Surround Receiver
