Setup Question Samsung F8000, Pioneer VSX 1020, Samsung BR, cable box and Apple TV - AVS Forum | Home Theater Discussions And Reviews
Old 12-07-2013, 07:02 AM - Thread Starter
Nitecapt's Avatar
Please forgive my ignorance on these systems, I'm getting to that age where I am not sure if I am applying the correct logic.
I just bought a Samsun F8000 65" and it has a lot of apps and features and will soon be hooking it up.
Now prior to the purchase of this TV, all of my peripherals (BR, Cable box & apple TV were input to the Pioneer Vsx 1020 which essentially sent everything up to the TV. The TV's speakers were shut off.
Now, suppose I want to avail myself to some features on the TV, like special apps or internet connectivity. How do I get the TV's audio to the pioneer so it can play out of my surround sound? In doing so will I screw up anything else?
Many thanks to all who reply
Ray
Nitecapt is offline
Old 12-07-2013, 09:08 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Connect an optical cable from the TV to an input on the receiver and then select that input to hear the sound. It won't affect anything else in your setup.
BIslander is offline
Old 12-09-2013, 04:56 PM - Thread Starter
Nitecapt's Avatar
Thank you...that did it!
Nitecapt is offline
Old 12-09-2013, 07:44 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Glad to help. Enjoy.
Samsung Un65f8000 65 Inch 3d Ultra Slim Smart Led Hdtv , Pioneer Vsx 1020 K 7 1 Home Theater Receiver
