4 Conductor 8 conductor, 2 conductor. What is the difference - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-27-2013, 09:34 AM - Thread Starter
jjohnston7's Avatar
I am looking to setup a system using cables with speakon ends. I found some that are labeled as 4 conductor, 8 conductor etc. How does this multi conductor work when all you need is 2? and what are the advantages of say 11/4 vs 10/2, or even 13/8?
jjohnston7 is offline
post #2 of 8 Old 12-27-2013, 09:58 AM
whoaru99's Avatar
Liked: 69
How the question is answered, to me, depends on the context of the application.
Can you be a bit more specific about the plan and system(s)?
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #3 of 8 Old 12-27-2013, 11:36 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The standard way to use Speakons for just one speaker is to use 1+ and 1- on a 4 conductor connector. I don't know why this is, but its the way that pro amps and speakers are wired up. The 4 conductor plug will also work on 2 conductor sockets.
For a fancier look, check out the metal ones:
The metal series includes a in-line female for fabricating Speakon extension cables.
arnyk is offline
post #4 of 8 Old 12-27-2013, 01:35 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
If you go to the Neutrik (Speak-On) site they have wiring guides. Multi-pin connectors are useful for balanced drive systems (which often use 1 as ground and 2 +/- for the speaker driver), multi-way (bi-amped/tri-amped/quad-amped) systems, running one cable to a stereo pair (with split-outs at the far end), etc. Look up one of the connectors then download the wiring guide for pictures of various schemes.
e.g. http://www.neutrik.com/en/speakon/stx-series/nlt4fx
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5 of 8 Old 12-27-2013, 01:59 PM
whoaru99's Avatar
Liked: 69
I think its the other way around... 2 conductor plug will mate with 4 conductor socket but not vice versa.
And, that sort of thing is where I was going earlier....inasmuch as if standard practices should be adhered to or if the system is such that potentially proprietary wiring may be acceptable.
whoaru99 is offline
post #6 of 8 Old 12-27-2013, 02:51 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That is correct and agrees with the illustration that I provided.
The picture was right and there should be no more confusion after it is interpreted correctly which you did.
arnyk is offline
post #7 of 8 Old 12-27-2013, 03:08 PM
whoaru99's Avatar
Liked: 69
The second part wasnt so much about the 2 vs 4, but more about how the OP might choose to use them. If they are used in a proprietary setup with no chance the cables will be used elsewhere or in the wrong place in the application, then one can wire'em up about any way one pleases. However, like in the situations of a sound company, standardized wiring and pinout makes things much easier from an inventory standpoint and less room for error when people are connecting things.
whoaru99 is offline
post #8 of 8 Old 12-27-2013, 05:25 PM - Thread Starter
jjohnston7's Avatar
Thanks everyone! that helps a lot. I think for my setup all I need is 2 conductor.
