Newbie Optical Audio Connector Question. - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2014, 07:05 PM - Thread Starter
pdxlarry's Avatar
Hi Folks:
   This should be the dumbest question anybody asks in 2014.
   I just purchased my first HDTV, a ZT60.
   This is also my first experience with optical audio.
   The optical audio connector seems to be covered with a plastic cap.  I've picked at it with my fingernails, but I'm reluctant to pry it off with a screwdriver, as I see that some of these connectors are covered by caps, and others apparently have "Doors" that open to access the connection when a cable end is pressed against them.
   Do I understand this correctly?
   What kind of cap is on the ZT60?
   What do I do to connect the cable?
      Larry
pdxlarry is offline
Old 01-07-2014, 07:23 PM
roadking00's Avatar
Quoted: 47 Post(s)
No cap at all on my VT, just plug in the opt connector right in....
roadking00 is offline
Old 01-08-2014, 06:25 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by pdxlarry View Post
Hi Folks:
This picture shows a Toslink port with the typical cap that has finger grips:
I've also seen caps that lack the finger grips and are just flat across. I pry them off with a small screwdriver tip.
This picture shows a Toslink port ready to receive a cable:
the Toslink port marked "Optical" has a little red light shining in it because it is an output port and the piece of equipment is turned on. If its an input port there is no light.
Output ports are basically LEDs, and input ports are phototransistors or high speed solid state light sensors. An ordinary LED can be used to drive a toslink input in a pinch.
arnyk is offline
Old 01-08-2014, 11:35 AM
FreakinSyco's Avatar
I've had cables with little rubber tips that needed to be removed before use. Both with the strap as pictures above and without. Google optical cable tips and make sure yours looks like the average one.
Edit: this is how most of my cable ends look. There are some other variations that use a large round clear plastic tip as well.
And on reading the first post better: the poster above has the correct answer.
FreakinSyco is offline
Old 01-08-2014, 02:16 PM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Ratman is offline
Old 01-10-2014, 03:33 AM - Thread Starter
pdxlarry's Avatar
Thanks Everybody:
   It's working.
   The question was related to the connector on the TV.
   The dealership where I purchased the TV had a floor model 65" ZT60, mine is a 60".  The optical port on this item had no cover.  A dim red light was visible when I looked into it.
   I gently pressed the tip of a small screwdriver against the cap that covered the opening for the optical cable.  I was expecting to feel a soft plastic plug that I would pop out.
   Instead, the cap flipped back into the hole, spring loaded and hinged on the bottom.
   The optical cable slipped in.
   So the optical socket for this TV has a tiny door.
   I appreciate everybody's effort to help me.
      Larry
pdxlarry is offline
Old 01-13-2014, 09:16 AM
scorrpio's Avatar
AFAIK, the 'dustplug' design of the optical jack is an older type. Almost all opticals you will find on recent equipment have the 'tiny door' design where the cable just pops in, no need to remove anything. Also, optical input is usually black, while output is usually gray.
scorrpio is offline
Old 01-13-2014, 10:06 AM
Ratman's Avatar
Liked: 1027
LOL! He resolved the issue 3 days ago. Where were you 5 days ago? biggrin.gif
Ratman is offline
Old 01-13-2014, 11:26 AM
scorrpio's Avatar
Yes, I know he did, so what? I just commented on the 'door vs dustplug' port design.
scorrpio is offline
Old 01-13-2014, 11:42 AM
Ratman's Avatar
Liked: 1027
Oh okay. Missed the smiley face I guess? If not, so what? biggrin.gifbiggrin.gif
OTOH.... some devices use plugs, some use doors. Thanks for the additional info.
Ratman is offline
Old 01-13-2014, 07:34 PM - Thread Starter
pdxlarry's Avatar
Yea, it's been a couple of days, but I appreciate the response.
pdxlarry is offline
