Advanced Room EQ, Acoustics and Optimization - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #301 of 303 Old 03-01-2014, 11:52 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Originally Posted by 3ll3d00d View Post
what does it do?
I'm not entirely sure, but it appears to use some form of decorrelation.
As I mentioned in the REW thread, I like a dead room.
Also as mentioned, I currently cannot measure the effect of the plugin. frown.gif
Front with your scale
And with a larger scale
Rears could use more work.
Audionut11 is offline
post #302 of 303 Old 03-05-2014, 10:14 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Jim, I apologise in advance, I haven't had the time to read more then what you have posted.
Originally Posted by jim19611961 View Post
It would appear to me, that the transition frequency is determined by the delay of the first reflections?
So the crossover frequency would be determined by the delay of the kicker, since it has become our first reflection?
In turn, this delay for the kicker, determines the spectrum, acoustical interference, sound quality and timbre, of the reproduced sound? Which, at least as represented in the image above, is heavily related to the room itself.
The boundary effects and room modes are a consideration of the room only.
So if we consider this.
With these reflections, they aren't generated by the room itself (not when using rear speakers, for sure), and hence, they shouldn't suffer from all the problems directly related to room issues (modes, boundary effects etc).
So it would seem prudent to me, to lower the frequency generated by the rear speakers, to gain an increase in envelopment.
Either that, or instead of trying to theorise about audio reproduction at 4am, I should just get some sleep instead.
post #303 of 303 Old 03-05-2014, 12:45 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
The transition frequency is determined by the room size. That is, where the modal dominance of the room ends. Therefore, the kicker has no relevance to this. Notice the time delay ranges given. Therefore, when considering reflections <80ms, the 500hz and up range is what we are concerned with for the perception of spaciousness.
Envelopment as Toole is illustrating it doesn't happen in small rooms given the need for them to occur >80ms. Small rooms don't generate significant reflections >80ms.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Room Equilizer Wizard Rew
