Stuck without sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-04-2014, 10:12 PM - Thread Starter
sirazpatel1's Avatar
Hey guys. It's 5 am and I'm losing sleep lol. Any advice would be super.
The problem
I have just purchased an epson emp tw520 projector.
I have only one hdmi port which my ps3 is connected to.
I Want 5.1 surround sound and I'm looking to purchase a sound bar Yamaha 101
However the projector has no optical cable port ...
Only one hdmi which is in use ...
How can I possibly enjoy movies with full surround sound on this projector ??
Any advice or solutions would be appreciated ...
Is the green 'y' next to cb/pb cr/pr for the audio cable ?? I'm sure if I connect the soundbar through that I won't get full 5.1. Surround.
Please help me to get surround sound
sirazpatel1 is offline
post #2 of 9 Old 02-05-2014, 04:05 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The problem
There are such things as HDMI audio extractors with optical outputs
http://www.amazon.com/ViewHD-Premium-Audio-Extractor-Converter/dp/B00AHS8LD8/ref=sr_1_1
and also HDMI splitters.
http://www.amazon.com/J-Tech-Digital-Registered-Trademark-Capability/dp/B008D66RAU/ref=sr_1_1
sirazpatel1 likes this.
arnyk is offline
post #3 of 9 Old 02-05-2014, 05:14 AM - Thread Starter
Thanks, if I use a splitter coming out of the projector going into ps3 and the soundbar wil it work at the same time ?? I was under the impression splitters are to split outgoing sources not bring 2 sources into one.. If that makes sense
post #4 of 9 Old 02-05-2014, 05:30 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Oh. my bad. Then you need a HDMI switch:
http://www.amazon.com/Kinivo-301BN-Premium-wireless-adapter/dp/B0049S6ZUS/ref=sr_1_3
arnyk is offline
post #5 of 9 Old 02-05-2014, 07:34 AM - Thread Starter
Lol I don't need that too! I've solved it. All I need to do is connect the soundbar to the ps3 via optical. Simples
post #6 of 9 Old 02-05-2014, 07:43 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It might be a good fix, or not so much in the long run. There are audio formats that run over HDMI, but not coax or optical. When you have the problem, you'll know it!
arnyk is offline
post #7 of 9 Old 02-05-2014, 09:02 PM - Thread Starter
But the soundbar has no hdmi port.. It only had the optical... It is the Yamaha 101. They advertised it as 5.1 and yes 7.1 lol
How could I possibly get this through an optical cable alone ?? Apart from telling me they lied to me can you enlighten me with some more of your wisdom please. Thanks in advance 😊
post #8 of 9 Old 02-06-2014, 05:29 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Don't worry about it. That soundbar will decode standard multi channel DD and DTS material via optical just fine.
Just remember that the soundbar will play a virtual (AKA fake) 5.1 or 7.1 type of sound. There are only two main channel speakers in that unit plus the subwoofer.
http://usa.yamaha.com/products/audio-visual/digital-sound-projector/yas-101/
J_Palmer_Cass is offline
post #9 of 9 Old 02-06-2014, 09:44 AM - Thread Starter
Any ideas on how to set my ps3 settings ?? Audio through bitstream or PCM ??
