Center speaker not working with 5.1 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-28-2014, 11:43 AM - Thread Starter
nick347b's Avatar
I'm setting up an older gen 5.1 Creative speaker system for my PC and everything is working great except that no sound, or hardly any sound is coming out of the center channel. When I do an audio test through the Reatek Audio Manager, I can just barely hear it through this channel. I tried swapping channels so the center channel came out of a different speaker and that speaker did the same thing and the middle speaker was fine. I tried boosting it to +10 dB in room correction and nothing changed. Any ideas?
nick347b is offline
post #2 of 5 Old 03-01-2014, 06:53 AM
Selden Ball's Avatar
Quoted: 3054 Post(s)
Liked: 1494
Exactly what model of speaker system is it?
How is it connected to your computer?
Your symptoms are consistent with either the computer's center channel output being defective or the speaker system's amplifier's center channel input having problems. It could be a bad solder join in the cabling or connectors, for example, or the electronics could be damaged.
Selden
Selden Ball is offline
post #3 of 5 Old 03-01-2014, 03:43 PM - Thread Starter
nick347b's Avatar
Creative Inspire 5.1 5300. It's connected by a 3-wire conjoined cable with male stereo at both ends, green for front speakers, black for rear and orange for center/sub speakers. They're connected to the motherboard which has HD Realtek audio. The sub is working fine, it's just the center speaker that's being weird. Again, it's not completely dead, it's just extremely quiet when I run the audio test and other than that it doesn't emit sound other than soft white noise like the others when I turn them on.
nick347b is offline
post #4 of 5 Old 03-02-2014, 11:35 AM
Liked: 1494
It isn't clear from your description which ends of the cables were swapped. If the center speaker still sounds bad when you swap only the connections at the input on the subwoofer, then the problem is in the speaker system, not in the soundcard or cable.
If it is in the speaker system, try swapping the old center speaker's cable at the subwoofer with one of the other speakers' output connection on the subwoofer. If the new center speaker sounds bad, and the old one is OK, then the problem is in the subwoofer and you'll have to get it repaired. If the old one sounds still bad, check its cable carefully. It might be damaged at one end or the other or in the middle. You might be able to fix it yourself.
Selden
post #5 of 5 Old 03-02-2014, 12:28 PM - Thread Starter
nick347b's Avatar
Yeah this is exactly what happened. Sorry for being unclear. One thing I did notice is that the male input for the center speaker can't physically go in quite as far as the other 4 speaker inputs due to the small circular niche around the female end not being quite as deep as the other four. But if the sub casing was designed like that, I don't see how that could be the problem... but at the same time it seems strange.
nick347b is offline
