REVIEW INCL. Just got monoprice speaker wire in.....why do you guys reccomend this so much? - Page 10 - AVS Forum
post #271 of 285 Old 03-22-2014, 03:42 PM
Colm's Avatar
Liked: 87
I find it odd that the Belden wire tests nearly 1/3 lower in resistance that is claimed for it. The claimed resistance is essentially standard for 12 AWG wire. I can understand a reputable brand testing a little better because the target size has to be a little bigger to ensure that normal manufacturing variability does not result in a substandard wire, but that much bigger doesn't make sense. I think there are some problems with how it was measured. That said, assuming the testing was consistent, I think the results are meaningful, particularly the ones that are well above standard.
There is more going on with the Fry's and Best Buy wire than being aluminum. The difference in conductivity between copper and aluminum doesn't account for the difference. The cross-sectional area of the wire must be smaller, too, or they are using some weird alloy. This is not a problem just with these two retailers. It is a problem at Home Depot, Lowes, Walmart, etc. If the label on the spool doesn't say copper, it probably isn't. Beware of familiar consumer brands like RCA, GE. When it comes to speaker wire, they aren't the same brands your father knew.
Kudos, Amir.
Colm is offline
post #272 of 285 Old 03-22-2014, 04:08 PM
Frank Derks's Avatar
Quoted: 97 Post(s)
Liked: 88
Perhaps a better reference would be a piece of solid core AWG12 installation wire. No guessing at wire fill % for the stranded wire.
Frank Derks is offline
post #273 of 285 Old 03-22-2014, 04:36 PM
Colm's Avatar
Liked: 87
I would guess there is less variability in a solid wire than stranded. But there is really no need for a reference wire. The resistivity, cross-sectional area, etc. of 12 AWG copper wire is well established in ASTM publications. All we need to do is compare observed results to the standard.
Colm is offline
post #274 of 285 Old 03-22-2014, 05:11 PM
fotto's Avatar
Thanks for the effort and expense on this exercise, however I agree with above two posts that Belden should not be the reference "baseline". It would be nice if you add AWG 12 solid copper as reference standard and repost the results, Should be easy to do at this point.
Furthermore, I am curious as to why you are using CL3 rated wire in these results vs. non CL3 rated. I think that could also skew results. Should all be non-PVC jacketed non-CL3 rated wire in my opinion. CL3 never entered the equation until you brought up the Belden 5000UP reference.
Lastly, why did you choose Belden 5000UP (advertised DCR of 1.56) vs. their 5000UE which has 1.6 DCR?
5000UP
5000UE
Edit: Adding to my point on CL rated vs non, Monoprice 12 Gauge non CL rated wire has resistance of .0072 ohms/meter for standard 12 gauge vs. .0054 for CL2 rated.
fotto is offline
post #275 of 285 Old 03-22-2014, 05:15 PM
bldxyz's Avatar
Well, I'm glad that's completely, 100% settled.
bldxyz is offline
post #276 of 285 Old 03-22-2014, 06:57 PM
cfraser's Avatar
Quoted: 13 Post(s)
Liked: 46
We are talking advertised gauge size, not plenum/etc. rating. Gauge is gauge, assuming we're talking AWG. CLx doesn't matter for the question(s) being answered.
And hey, the much more expensive Belden cable I use/mentioned is rated as 1.6 DCR too. Maybe they rounded. smile.gif
cfraser is online now
post #277 of 285 Old 03-22-2014, 09:02 PM
amirm's Avatar
Quoted: 548 Post(s)
Liked: 340
Sure. I think I have some solid electrical wire I can test and report back. Not home right now so it won't be for a few days.
On the first, it just was what I had on hand. Thought the more samples the better. On the Belden, that was because of this thread. If you look early on I picked the first Belden speaker wire that popped up in the search. Since we had done our analysis in this thread based on that, i thought it was good to also test that.
Initially I was just going to test OP's cables which were RadioShack and Monoprice. So the rest of the additions were rather ad-hoc. I am hoping others provide whatever samples they want me to test. I have way too much speaker wire on my hand to buy more smile.gif.
Amir
Founder, Madrona Digital
"Insist on Quality Engineering"
amirm is online now
post #278 of 285 Old 03-22-2014, 09:04 PM
amirm's Avatar
Quoted: 548 Post(s)
Liked: 340
Amir
amirm is online now
post #279 of 285 Old 03-22-2014, 09:09 PM
DonH50's Avatar
Quoted: 105 Post(s)
Liked: 240
Nice job, Amir. And the responses show why I don't bother to even try to post measurements here.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #280 of 285 Old 03-22-2014, 11:08 PM
krabapple's Avatar
Quoted: 89 Post(s)
Liked: 155
the mountain has laboured and brought forth a mouse
jeffleonard likes this.
krabapple is offline
post #281 of 285 Old 03-23-2014, 07:28 AM
exm
exm's Avatar
Liked: 55
exm is offline
post #282 of 285 Old 03-23-2014, 04:30 PM
DS-21's Avatar
Quoted: 48 Post(s)
Liked: 160
Originally Posted by lynchking View Post
monoprice stuff rots in the closet and I have the auvio hooked up
Why not just toss the MP, or give it to Goodwill, etc.? It's not very good stuff, I agree. It turns green, and the insulation does not survive in high heat/humidity applications such as cars. Monoprice's "in wall" wire is just fine, but I don't like the zip cord at all.
Originally Posted by amirm View Post
***The coat hanger actually went past the bottom of the graph so whatever story there is on how it sounds is quite suspect.
Careful. You've taken measurements but haven't done any listening tests. All that can be said is that they measure differently, not that they sound different. Chances are much more likely that, for a run the length of a coat hanger, anything will do from an audibility standpoint.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
Multichannel music (and video) urban loft living room system
DS-21 is offline
post #283 of 285 Old 03-23-2014, 04:57 PM
Skytrooper's Avatar
Liked: 78
I spent more on my in wall speaker cable not for a audible reasons, but for durability. As stated above, I did not want my wire turning green or have the insulation breaking down. It gets dam hot in my attic.
(LCD - Sony KDL - XBR4) (Receiver - Sony STR-DA4ES)(Blu Ray - Oppo BDP-83) (PS3)( Dish Hopper DVR With Sling) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #284 of 285 Old 03-23-2014, 07:25 PM
DS-21's Avatar
Quoted: 48 Post(s)
Liked: 160
I hope nobody's using the monoprice zip-cord for in-wall installations! It's not rated for that.
FWIW, stuff I currently use in for my in-wall speakers from Carol. I don't remember the model number but it has thin insulation, a tight jacket, a slight twist, and a CL3P in-wall rating. It was a bit more than $100 for a 250' 12/2 roll. One always underestimates how much wire one needs for a multichannel system, especially if it has 7 or more speakers and 3 or more subs with centrally-located amplification for all of them. So often s 250' roll is a prudent buy.
Serious Audio Blog
DS-21 is offline
post #285 of 285 Old 03-26-2014, 03:02 PM
bldxyz's Avatar
The check is in the mail.
bldxyz is offline
Reply Audio theory, Setup and Chat
User Tag List
