How to get best two-channel sound from home theater receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-06-2014, 12:11 PM - Thread Starter
degoon's Avatar
Want to get the best stereo sound using a windows PC as the music source. I have a Dell Inspiron 660s with an HMDI output on the motherboard (back of the PC). If I connect the PC to my NAD surround receiver via HDMI, is this the best option?
I don't really clear how the different file qualities work and where they are processed. For example, what's the difference if using a media player on the PC to play an mp3 vs FLAC? My NAD has a onboard DAC. Where does the DAC fit in?
Sorry if not clear, but I'm new to this and any insight would be appreciated!
degoon is offline
post #2 of 17 Old 03-06-2014, 12:29 PM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
1.  Identify the NAD AVR.  Does it have a USB input?  What you suggest with HDMI will work fine but there may be other options.
2.  It depends on how you connect things.  With the HDMI, all the files will be decoded in the AVR.  MP3 is a lossy, low resolution format compared to FLAC.  The DAC inside is used for all digital to analog conversions.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 17 Old 03-06-2014, 12:42 PM - Thread Starter
degoon's Avatar
Thanks Kal,
The receiver is a NAD T775HD. It (unfortunately?) does not have USB inputs.
Is this correct:
Use the PC to play the best quality files possible;
digital data will then be sent over HDMI to the NAD receiver;
which will then processed using the onboard DAC?
The better the quality of the file, the better job the DAC can do?
How might having USB inputs be better?
degoon is offline
post #4 of 17 Old 03-06-2014, 12:56 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
Thanks Kal,
Is this correct:
Best practice is to leave the data in digital form as far down the line as possible. So, all things being equal, using the DAC in the receiver is better practice than using the DAC on the sound card. So using HDMI would be a good approach. The DAC will decode whatever is there, assuming it supports the particular format.
If the digital file has a better rendition of the music, then it will sound better after conversion. Check to see what formats you can decode and choose a format that will do the job for you. As Kal says, a lossless format will retain all of the data so it won't sound any different than a CD.. The quality of lossy formats depends on how much compression is used. It can range from indistiguishable from a CD to downright awful.
FMW is offline
post #5 of 17 Old 03-06-2014, 01:08 PM
Quoted: 771 Post(s)
Liked: 542
Thanks Kal,
Is this correct:
Correct.
The better the file the better the sound.
Theoretically, HDMI has more jitter than S/PDIF but I do not think it is much of an issue.
The only improvement option might be to add a high quality external DAC like the NAD M51 and connect that to an analog input on the T775.  The downside to that is that you would give up Audyssey.
Kal Rubinson
post #6 of 17 Old 03-06-2014, 01:41 PM
Ratman's Avatar
Quoted: 1475 Post(s)
Liked: 1179
Originally Posted by Kal Rubinson View Post
Theoretically, HDMI has more jitter than HDMI but I do not think it is much of an issue.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #7 of 17 Old 03-06-2014, 01:51 PM - Thread Starter
degoon's Avatar
Originally Posted by Ratman View Post
Thanks for clearing this up for me Kal and FMW. Great answers. Now my obsessiveness can rest in peace. tongue.gif
degoon is offline
post #8 of 17 Old 03-06-2014, 02:58 PM
Quoted: 771 Post(s)
Liked: 542
Against what?  I am basing it on my personal experience which, of course, might not be universal.
Kal Rubinson
post #9 of 17 Old 03-06-2014, 03:10 PM
Ratman's Avatar
Liked: 1179
Read closely. You stated:
"Theoretically, HDMI has more jitter than HDMI ..."
post #10 of 17 Old 03-06-2014, 03:11 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #11 of 17 Old 03-06-2014, 03:40 PM
Quoted: 771 Post(s)
Liked: 542
Originally Posted by beaveav View Post
Duh.  Why not be explicit about my typo?
Kal Rubinson
post #12 of 17 Old 03-06-2014, 03:53 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Yeah, you're absolutely right - but for some reason it's more fun to let you find it yourself. Maybe because I have the maturity of a five year old? wink.gif
beaveav is offline
post #13 of 17 Old 03-06-2014, 04:02 PM
Ratman's Avatar
Liked: 1179
Well in all fairness... being a "Senior Contributing Editor", you should be able to find/correct your own typos.
post #14 of 17 Old 03-06-2014, 04:13 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
eh, that's kind of a cheap shot, dontcha think?
beaveav is offline
post #15 of 17 Old 03-06-2014, 05:06 PM
Quoted: 771 Post(s)
Liked: 542
Perhaps (although we have copy editors for that) but there was nothing in your reply to distinguish it from a disputation of my opinion.  Consider it a "senior" moment.:p
Kal Rubinson
post #16 of 17 Old 03-07-2014, 05:14 AM
Ratman's Avatar
Liked: 1179
post #17 of 17 Old 03-07-2014, 05:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Actually, being almost anything but the lowest life in the editorial office means that someone else is there to correct your typos. ;-)
arnyk is offline
