New to this ... In wall speaker cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-16-2014, 07:53 AM - Thread Starter
Hurley916's Avatar
Hello,
First home buyer...setting up the basement with an okay setup.
I have a Yamaha V575...I don't have speakers yet.
Just wanted to double check that I am buying the correct speaker cable. I bought the below 16g:
http://www.amazon.com/gp/aw/d/B0044YPN0A/ref=mp_s_a_1_3?qid=1394977599&sr=8-3&pi=SY200_QL40
I will be running this through my drywall about 25 ft to the rear speakers.
I'll only be using 5.1 for my TV and will be setting up the other 2 speakers to use in another room (if possible).
Will that wire work for me or should I be looking at something else?
I'm open to speaker suggestions also-not looking for anything great, just somewhere between entry level and mid-level to get my home theater going for now. Probably looking at spending about $700 or so for the speakers + subwoofer. About a 12' x 12' viewing area for the TV room. The room is actually bigger, probably about 33' x 24'
I appreciate any help. Really just need the wire question answered if possible.
Hurley916 is offline
post #2 of 2 Old 03-16-2014, 10:06 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by Hurley916 View Post
Hello,
If its in the wall then it has to be code. To be sure use cable marked CL2 or CL3:
http://www.avsforum.com/t/914474/cl3-or-cl2-for-speaker-wire
arnyk is offline
