Took the advice, Setup my room between absorption and diffusion. WOW - AVS Forum | Home Theater Discussions And Reviews
Old 03-19-2014, 09:46 PM - Thread Starter
Michael Adkins's Avatar
So i been struggling getting things to sound good in my room.   Just funky sound. Really did not seem to have that surround effect. Room seamed flat! I changed speaker locations speaker brands eq settings crossovers you name it.
After getting ready to give up I figured let me listen to the pro's. Watched some videos on the matter.  Went out and made 2d and 3d reflection panels and absorption panels..
First thing i noticed was the room sounded different just sitting in it. Talking everything.  The fan on my projector which was non existent before seemed loud now.
I popped in a live track, Adel performing live @ the Royal Albert Hall.  Right away I noticed a ton of things. ONE, some of my speakers were rattling against the wall. Stuffed a paper towel between wall and mount quick to kill noise. TWO, My surround speakers seemed LOUD, TO loud i had to lower almost 6db.
Once I made some tweaks the room just lit up.  I know could tell there was a left center and right channel. It sounded like I was standing in the theater with her.  My center speaker always seemed to have this raspy distortion to it.  Now Deeper tones and it sounded so full.
This was what I have been searching for! ALL ALONG.  This goes to show you that the room is the MAIN component in your system. No matter what speakers what amps you have a untreated room kills these wonderful products.
I spent under 500.00 In materials and did it myself.  And if I would spend double or triple this to get these effects.
If you are here wondering does it really matter? Is it worth it....    DO IT! Do your speakers a favor, DO yourself a favor your not allowing your speakers to do what they were designed to!
Thanks for all the help. I cant believe it sounds the way it does now!
I still need to cover the panels. But for now I found I could not leave the room!  Enjoy guys I hope this helps someone else find the hidden sound!
tacodan likes this.
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
A few 18" subs here and there!
LFE ADDICT
Michael Adkins is offline
Old 03-20-2014, 07:40 AM
tacodan's Avatar
Where did you get the info on how prepare the room. I don't even know what are "2d and 3d reflection panels and absorption panels". I feel my room needs some treatment.
tacodan is offline
Old 03-20-2014, 07:42 AM
trueno92's Avatar
needs pics and links to videos of what you were talking about...
trueno92 is offline
Old 03-20-2014, 11:31 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Testify brother!
For the others, here are some links. This short article is mainly about home recording, but all the same principles apply to hi-fi and home theater acoustics too:
Acoustic Basics
These articles and videos explain more:
How To Set Up A Room
Early Reflections
All About Diffusion
Hearing is Believing
Again, some of the material addresses recording studios, but it all applies to your rooms too.
--Ethan
tacodan likes this.
Ethan Winer is offline
Old 03-20-2014, 07:52 PM
tacodan's Avatar
Thanks guys, you really saved me from going the wrong way!
tacodan is offline
Old 03-21-2014, 06:55 AM
tacodan's Avatar
Real Traps are very expensive. You said you did it yourself. Can you tell us where did you get the info on what materials you used and how to build the panels?
tacodan is offline
Old 03-21-2014, 07:54 AM - Thread Starter
I will gladly make a little write up.   I been very busy with work. But pictures of building process and more info to come! :)
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
LFE ADDICT
Old 03-27-2014, 12:05 PM - Thread Starter
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
LFE ADDICT
Old 03-27-2014, 01:04 PM - Thread Starter
Paint and fabric coming soon but setting up panels and MIC'ing the room. So far i have lowered some freq by -15 db at delayed points of 60MS plus.
Really working well.
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
LFE ADDICT
Old 03-27-2014, 01:57 PM
jamhead's Avatar
Excellent work on the diffusion!
I can see why you were having problems after looking at your room.
One thing you can add, as time and $$ allows, is bass trapping. That made, by far, the biggest impact on sound in my room. Not only did it help lower frequencies, but also the mids and highs.
Good job!
jamhead is offline
