The age old question....My wife said I can spend <$1000 on 5.1 speakers... - AVS Forum | Home Theater Discussions And Reviews
Old 03-24-2014, 02:14 AM - Thread Starter
Saitac's Avatar
All ye wise men - help a young bloke out?
I'm a bit of an audio greenhorn and I'm rather overwhelmed by my options.  I've got a 100" projector/screen that I'm looking to marry some audio to but my wife is only half sold on the whole idea and has set a budget.  I was considering buying the Definitive Technology ProCinema 600 package (PM600x4,PC600,PS600) because it fit easily in my price range and would leave room for a decent receiver with the bells and whistles but I'm a bit underwhelmed with the sub and concerned about it filling my big room.
Then I saw the PM800's and started matching it up with the PC1000 but I read you should pass the speaker cables through the sub's output for best performance???? Since when did that catch on....  If I get a different brand sub would I still want to do that?
I've got a 15'x20' room with a 9' ceiling.  I haven't picked out a receiver but I've got to stay UNDER $1,000 on the 5.1 speakers.  I can't do towers - the speakers have got to be wall mounted.
I like the sound of the DT brand but am open to anything that can wall mount and is under $1,000 as a whole 5.1.  If I can get speaker's+receiver for $1,200 the wife will even give me bonus points.
The receiver is a bit complicated with the video implications but I'm all ears there too.
So, 5.1 speaker recommendations < $1,000 (w/no towers)?
Thanks in advance - you guys are awesom!
Saitac is offline
Old 03-24-2014, 06:15 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Where did you read that you should run the speakers through the sub? That was a common approach many years ago. These days, the usual approach is to run everything through the receiver. The AVR does all of the processing and has a pre-out that sends the sub only the audio that it is supposed to play (LFE and redirected bass from bass management). The sub has its own power source.
BIslander is offline
Old 03-24-2014, 06:52 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
+1
arnyk is offline
Old 03-24-2014, 12:31 PM - Thread Starter
Saitac's Avatar
The sub link up method was in the linked cnet article..
http://www.cnet.com/products/definitive-technology-procinema-600/
 You can hook up the ProCinema the usual way and run all the satellites as "Small" speakers and let your AV receiver handle bass management, but Definitive recommends an alternate hookup method to maximize sound quality. Basically, you run the front left and right speaker cables to the corresponding inputs on the subwoofer, and then run a second pair of cables to the actual speakers. Indeed, it does sound a bit better--producing a better blend between the satellite speakers and the subwoofer--but it was somewhat annoying to have to deal with those extra cables.
I'm leaning towards 4xPM800's, PC1000, and some sub - not sure there.  Any thoughts?
Saitac is offline
Old 03-24-2014, 12:33 PM - Thread Starter
Saitac's Avatar
Can't link - no permission yet. Anywho - it's kind of below.
w w w .cnet. com/products/definitive-technology-procinema-600/
A quote from the article...
I'm leaning towards 4xPM800, 1xPC1000, and some sub - not sure there.
Any thoughts?
Saitac is offline
Old 03-24-2014, 12:35 PM - Thread Starter
Saitac's Avatar
For pete's sake - 3rd attempt trying to reply.  I can't reply with links.  I was going to link to the cnet article that talks about it.  If you google ProCinema600 review - it's in the cnet article.
Here's a quote....
I'm leaning towards PM800x4, PC1000, and some sub - not sure on the sub yet.
Any thoughts on a <$1,000 5.1?
Saitac is offline
Old 03-24-2014, 12:36 PM - Thread Starter
Saitac's Avatar
For pete's sake - 4th attempt trying to reply.  I can't reply with links or quotes or images.... yeesh.  I was going to link to the cnet article that talks about it.  If you google ProCinema600 review - it's in the cnet article.
I also can't quote it apparently but they said DT recommends their alternative hookup style - through the sub....
Saitac is offline
Old 03-24-2014, 03:49 PM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
I don't know why they would recommend that, all you're doing is using your subwoofer's crossover instead of your AVR and complicating things by having to run a bunch more cables, which also complicates your sub placement options.
Osirus23 is offline
Old 03-24-2014, 04:03 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Probably because the speakers have a severely limited low-end capability. And maybe because it is a dated recommendation.
And you wouldn't be running them through the sub's "crossover". Subs don't have crossovers; they have variable low-pass filters and sometimes (as is probably the case, here) a fixed high-pass filter which is applied to any directly-connected speakers.
With those speakers and the continuously variable low-pass filter on the sub (no idea what its slope might be), you may be able to better adjust the overall sound quality than what can be achieved by using an AVR's crossover, which usually has a 24dB/octave low-pass filter and a 12dB/octave high-pass filter.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 03-24-2014, 05:02 PM - Thread Starter
Saitac's Avatar
I think I hijacked my own thread onto a "hook your sub up" topic :/  mwahahhAHAHAa I have the POWER!
Any recommendations/thoughts on the <$1,000 5.1 gear??
Saitac is offline
Old 03-24-2014, 06:46 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Are you completely averse to starting with less than 5.1 and adding more speakers/sub(s) later?
Old 03-24-2014, 06:52 PM - Thread Starter
Saitac's Avatar
I'd be willing to start with 2 or 3.1 but I'd the whole setup to stay under $1500 at 5.1. Is there really nothing for $1000 at 5.1?
Saitac is offline
Old 03-24-2014, 07:13 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Any thoughts?
I'm not a DefTec fan.
I've done well with Infinity Primus line - often P363s are dirt cheap which is the deal of the century. P143s and 163s are good surrounds and the PC351 is a great center. That leaves moolah for a BIC Acoustech PL200 or BIC America F12 subwoofer.
arnyk is offline
Old 03-25-2014, 01:06 AM - Thread Starter
Saitac's Avatar
Wow... nice setup by my eye.
BIC PL-200 = $329
IP PC351 = $275
IP P163 * 2 = $260 (130/per)
IP P143 * 2 = $120 (60/per)
TOTAL = $984.... free shipping from Amazon
Great scott man - you've done it!!  And a might better then the system I was thinking of.
Any other suggestions (like per channel wattage on a receiver...)? I'll be pulling the trigger tomorrow...
Thanks for the hand holding I needed it.
Saitac is offline
Old 03-25-2014, 01:39 PM
Jack D Ripper's Avatar
Liked: 272
BIC PL-200 = $329
IP PC351 = $275
If I were buying Infinity Primus speakers, I personally would go with the Infinity Primus P153 for all channels (currently $75.71 each at Amazon), and then have more money for the subwoofer.  That model seems to go deep enough for an 80Hz crossover.  You could then step up to an SVS PB-1000, which is a significantly better subwoofer.  And you would have perfect voice matching for all channels, as they are the exact same speaker for all channels.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
Old 03-25-2014, 02:02 PM
htcritic's Avatar
Before I'd "rush" out to buy the first thing somebody recommended that was in my price range, I'd relax, take a breath, and looked into used. Audiogon, etc where you can get great deals. hell, I easily have $5,000 worth of speakers in my system that I paid less than $1,500 for.
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures ...
htcritic is offline
Old 03-25-2014, 09:02 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Buying used speakers is one of the riskiest plays around. Shipping is a killer and hidden damage is a major exposure.
arnyk is offline
Old 03-25-2014, 10:02 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Sure it's a risk - but you can get some great deals. I have bought and sold - getting and giving great deals.
The other thing to do is look for end-of-line selloffs. Find some great speakers that are being sold off cheap (I got my 5.0 when the Kef iQx series were ending for $700, excellent deal).
rick240 is offline
Old 03-26-2014, 10:10 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
BIC PL-200 = $329
IP PC351 = $275
You can save some money on the Primus speakers by waiting for a sale by Amazon or Crutchfield, getting open box from Crutchfield, refurbished units from the Harmon store online (when in stock) or from Fry's if you have on nearby.
What is your timetable?
bladerunner6 is offline
Old 03-26-2014, 10:42 AM
Liked: 272
Since he is, as he states, "an audio greenhorn," I agree with you. Buying used requires knowing what one is doing, or being lucky. And it is also much, much better to buy used locally than remotely, because of shipping costs and shipping damage, but also so that one can see and hear what one is buying before one parts with one's money.
So, I think he would be much safer buying new from authorized dealers, so that he gets things with a warranty, and without previous wear and tear.
That said, if one knows what one is doing, and is careful, one can often get much better deals on used gear. If one screws up, though, a mistake can be costly.
Old 03-26-2014, 02:20 PM
htcritic's Avatar
For about 4-5 years I bought used speakers just so I could get an opportunity to listen to a bunch of different speakers for the fun of it. Once I was done, I sold them and moved on to another pair. I listened to Dunlavy, NHT, Aerial, Infinity, Vandersteen, Monitor Audio, Legacy, and Triangle. I always got killer deals, always made my money back, and never received a single damaged speaker. Not one. I used mainly Audiogon, always insisted on speaking with the sellers, and never got burned. Right now I have a pair of Triangle Antal ESW's that I picked up in mint condition for $450. I just don't see how you can go wrong buying used if you use a little common sense. I'm looking out for a pair of NHT XD's if I see a god deal and sooner or later...I will!
htcritic is offline
Old 03-26-2014, 04:28 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
KEF e305.1
http://www.kefdirect.com/e305-system.html
Keep an eye out for special offers, stretch the budget or look on ebay.
http://www.ebay.com/itm/271411649400?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That is not my listing, just know it is out there as I had a search for these.  I bought mine from kefdirect in their Christmas sale.
They also have great WAF.
SMHarman is offline
Old 03-26-2014, 04:53 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Agreed - some speakers are difficult and expensive to ship like large floor standing speakers. Others are inherently easier to buy used and have shipped - like smaller bookshelf speakers. There is some risk, but the rewards can be huge if you have the patience. My best find was my pair of brand new piano black Paradigm Signature S4 v.2 speakers with Be tweeters - discontinued in 2010, I found a pair in the original factory sealed boxes on eBay for about half of the original list price - I would have paid list for these brand new discontinued speakers but got a deal.
If you require (or the seller site requires) the seller to backup the sale and allow return if not as described you will get a much more honest seller that works harder to disclose issues up front and properly pack the speakers so they are not damaged. I look for speakers in their original packing and boxes and I usually ask for a 15 day return for any performance issue and ask the seller to double box or wrap original boxes in an additional layer of cardboard - it has helped. My experience with 5 used speaker purchases: (2) purchases were perfect, (2) purchases had broken grilles when they arrived (shipper insurance purchased new grilles both times) and 1 speaker had a "static" sound from the mid-range driver on very quiet passages. In the last case, the seller paid for a brand new driver from the manufacturer and I installed it - perfect result. Can be challenging but as other say you can get the speakers you really want for 50% or even less of their original cost - world class speakers on a realistic budget.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
Old 03-27-2014, 11:18 AM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Another low cost / high value brand to listen to before deciding is Polk. A friend of mine has speakers from the "Monitor Series" and for the price they blow my mind - check these out for under $500:
Polk Audio Monitor Series 45B - $160/pr
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290269
Polk Audio Monitor Series 25C Center - $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290281
Polk Audio Monitor Series 35B - $100/pr
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290268
mtn-tech is offline
Old 03-27-2014, 12:19 PM
Liked: 272
I think it would be better to go with RTi series speakers for $175/pair direct from Polk via their eBay site:
http://www.ebay.com/itm/360804038210?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
RTi is a higher line than the Monitor series. It also has a nice real wood veneer finish, which is hard to get at this price point.
Old 03-31-2014, 02:36 PM - Thread Starter
Saitac's Avatar
Thanks for all the replies guys.  I went with a super cheap 3.1 off of craigslist (I have no audio otherwise) for now and bought the discontinued Onkyo 818 for $600 which is the receiver I'd been eyeballing for a couple weeks (  Audissey XT32 + 2 HDMI out + OSD for <$1000 :)  ).  After reading all the comments here and other threads I think I need to spend $1000+ to really get what I want in speakers. Also, I'm going to need to take my time and maybe wait for a sweet deal.  The 3.1 cost $50 and is just to get audio out of my projector until I figure something out.  You guys rock!!
Saitac is offline
