monoprice 10565 - connect to HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2014, 09:31 AM - Thread Starter
jywc55's Avatar
Hello,
I just picked up a set of Monoprice 10565, but have yet to purchase an A/V receiver.
My HTPC motherboard has inputs for 7.1 ch audio (http://www.asrock.com/mb/AMD/A75M-ITX/index.us.asp).
Is it possible to purchase wires/connectors that will allow me to hook these speakers up directly to my HTPC?
Please advise!
jywc55 is offline
post #2 of 3 Old 03-31-2014, 09:55 AM
walterappleby's Avatar
Quoted: 26 Post(s)
Liked: 77
I assume that you mean your HTPC Motherboard has OUTPUTS for 7.1.
It's not a matter of wires/connectors for hooking it up... you need an amplifier, either internal to the receiver you will purchase or separate. You will not be able to use these speakers with only the line level power coming off the motherboard. (Except for the subwoofer. It has an amp so you would be able to use that with the line level output. But the sub without the speakers probably isn't what you are going after...)
Buy a receiver and this gets a lot easier.
jywc55 likes this.
walterappleby is offline
post #3 of 3 Old 03-31-2014, 01:51 PM - Thread Starter
jywc55's Avatar
Yes, outputs of course!
Ah. I see. It's all about power eh. Darn. I'll keep my eyes peeled for a receiver, then.
Thanks for such a quick reply!
jywc55 is offline
