4 speakers 4 wires 6 Conductors per wire need wire diagram - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-05-2014, 11:07 PM - Thread Starter
heero200's Avatar
Recently bought a house with 4 pre wired speakers with 6 conductor wire, just need help with a wire diagram to simple receiver. Please!
heero200 is offline
post #2 of 11 Old 04-06-2014, 05:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
You need a continuity tester or an ohm meter and some logic to figure out which are hots, and which are grounds.
So you are saying that there are 4 speakers, and six wires?
The logical way to do that would be to have separate grounds for left and right, and separate hot wires for each speaker.
The grounds can be identified by the fact that they are connected to 2 hots each.
arnyk is offline
post #3 of 11 Old 04-06-2014, 07:17 AM - Thread Starter
heero200's Avatar
There are 4 14/6 wires, red black blue green white brown are coming out of each of the 4 wires coming out of the wall
heero200 is offline
post #4 of 11 Old 04-06-2014, 07:44 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
the logical way to wire that would be half the wires to hot, half to ground, for each of the 4 speakers.
You still need the ohm meter or continuity tester. 3 wires in each bundle would be hot and shorted together, the other 3 ground and shorted together.
arnyk is offline
post #5 of 11 Old 04-06-2014, 08:34 AM - Thread Starter
heero200's Avatar
So then how would I wire the three I find hot together to wire to my receiver?
heero200 is offline
post #6 of 11 Old 04-06-2014, 11:11 AM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Look at the colors of wires at the back of each speaker?
Ratman is offline
post #7 of 11 Old 04-06-2014, 12:55 PM - Thread Starter
heero200's Avatar
Was trying to do it without crawling in the attic lol
heero200 is offline
post #8 of 11 Old 04-06-2014, 02:30 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
3 wires that are connected together to the appropriate channels hot or red terminal, The other 3 wires that are connected together to channel ground or black terminal for the same channel.
You can use a 9v battery to identify which wires go to which speaker. The battery will make the speaker click when you hook it up to the appropriate wires.
arnyk is offline
post #9 of 11 Old 04-06-2014, 02:52 PM - Thread Starter
heero200's Avatar
Gotcha! Thanks!
heero200 is offline
post #10 of 11 Old 04-06-2014, 02:52 PM - Thread Starter
heero200's Avatar
I looked at it again closer and they separated them for me, now I just have to determine +/-
heero200 is offline
post #11 of 11 Old 04-06-2014, 04:17 PM
Ratman's Avatar
Liked: 1027
I would take a crawl in the attic and do it right. Especially now that it's still cool.
Ratman is offline
