Any quality degradation from using a 3-pin US to 3-pin UK adapter? - AVS Forum | Home Theater Discussions And Reviews
Old 04-29-2014, 01:45 AM - Thread Starter
Balbolito's Avatar
Quoted: 24 Post(s)
Liked: 30
I am using 3 Wireworld 1m Aurora power cords on my 3 Emotiva Amps, now i want to upgrade everything else to the same cable.
One question, i would like to order a few Wireworld Aurora power cords from the US to be shipped to me in the UK as they are exactly half price, but the thing is that in the UK the 3-pin plug they use is different than the US 3-pin, so i would have to get something like this to use the US cord.
Will this in any way degrade the quality of the power cord used?
any tips would be appreciated.
Regards
Balbolito is offline
Old 04-29-2014, 05:03 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Regards
Yes it will if you believe it will. Why only concern yourself with the last 2 feet of cable in a 100's of miles long stream? You will also need to check the splices on the outside transformer pole and work you way back through the power grid to the power station checking everything.
William is offline
