Would this speaker layout work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-05-2014, 12:42 AM - Thread Starter
VectorLabs's Avatar
Quoted: 78 Post(s)
Liked: 52
Since the TV is in a corner and seating space surrounds it would this be an ok layout for my rears? I am going phantom center because the space where the TV sits is small. For reference the TV is 32" and takes up the entire corner cutout length wise.
VectorLabs is offline
post #2 of 4 Old 05-05-2014, 11:43 AM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 361
You might do better to put the TV in front of the wall at the top of your drawing, with the speakers firing toward the bottom. Even better is on the right wall firing to the left, unless that's a window and the TV would block it. More here:
How To Set Up A Room
--Ethan
Ethan Winer is offline
post #3 of 4 Old 05-05-2014, 05:10 PM - Thread Starter
VectorLabs's Avatar
Quoted: 78 Post(s)
Liked: 52
--Ethan
Sorry I should have been more detailed in my drawing. The wall in front of the big couch is actually a giant window seat so TV can't go there. Then the wall firing to the left with the bump on the drawing is a big built-in bookshelf that can't go anywhere.
post #4 of 4 Old 05-05-2014, 05:29 PM
mogorf's Avatar
Quoted: 1115 Post(s)
Liked: 709
Drawing and added narratives are OK, but real life photos around the room would be more help if you'd really like to get efficient help. Your situation is not easy, but let's not give up from the beginning! smile.gif
mogorf is offline
