Why do frequency responce graphs have larger spaces between different frequencies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-15-2014, 11:37 AM - Thread Starter
truwarrior22's Avatar
Quoted: 333 Post(s)
Liked: 77
Is it mainly to aid in crossover design? I think it odd that 10-20hz get's a big gap while 900hz-1khz get's a small gap.
Thoughts?
truwarrior22 is offline
post #2 of 5 Old 05-15-2014, 11:55 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Frequency response is plotted using a semi-log graph, which uses the same width for each octave. The octave between 500 Hz and 1 KHz is "worth the same" as the octave from 5 KHz to 10 KHz. This also more closely correlates to how we hear.
--Ethan
Ethan Winer is offline
post #3 of 5 Old 05-15-2014, 12:27 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Ethan is correct...
If you plot every note on a piano they will all be evenly spaced on the logaritmic FR curve.
On a linear chart, the bass notes would be crunched together, and the treble notes far apart.
Here are all 88 frequencies corresponding to every note on a piano.
Log Frequency Scale: all notes are evenly spaced on the chart, just as they are "evenly spaced" to your ear.
Linear Frequency Scale: Bass is scrunched together, higher notes farther apart
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #4 of 5 Old 05-15-2014, 12:39 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Thoughts?
+1 to the above. In your example, the 10 - 20 Hz difference is an octave. If you could find a piano that went down to 10 Hz, you'd play all twelve notes of the western musical scale to get to 20 Hz, one octave up. On the other hand, from 900 to 1000 Hz is just about two steps of the scale (although no notes actually hit exactly at 900 and 1000 Hz with normally tuned instruments . . .
JHAz is offline
post #5 of 5 Old 05-16-2014, 11:47 AM
Quoted: 264 Post(s)
Liked: 359
I'll add that the same applies for the volume scale vertically. Decibels are already logarithmic, so the horizontal lines are evenly spaced one above the other. But if you were plotting volts instead of dB, the vertical scale would also be log. That's called a log-log graph rather than a semi-log graph.
--Ethan
