DTS Coax to 3.5mm?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-23-2014, 09:16 AM - Thread Starter
Liked: 0
Question DTS Coax to 3.5mm??
Hi AVS forums.
I have been searching all over the place for an answer and no one seems to know if there is such a thing.....
Basically I have a Sony Blu-Ray (BDP-S1100) player which has a DTS/PCM/Dolby coaxial output for sound (phono). (there are no other outputs).
I have a Logitec 5 speaker and sub system which I have used in the past and wanting to see if it will work ok with the Sony.
The speaker system operates off a 3 way 3.5mm as an input.
Is there such a cable that is DTS/Dolby coaxial (preferably male) to 3 way 3.5 mm jack (preferably female).
As far as I can tell there isn't such a thing but just wanted a definitive answer ???
Oh and I am from the UK if that is relevant?!
Jon Faulkner is offline
post #2 of 4 Old 06-23-2014, 10:13 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Are your speakers passive or active with a S/PDIF input?
EDIT: Just a quick look on the logitech site and they are mostly PC type speakers systems. Which are active with analog inputs. If so then the answer is NO.
You need 3 things go from a DTS/DD stream to audio at the loudspeaker and you (may) only have 1.
1) DTS/DD decoder
2) D/A converter
3) Amp (which may be built into your speakers)
William is offline
post #3 of 4 Old 06-23-2014, 01:55 PM
scorrpio's Avatar
If this is a high end system like Z5500, it should have coax digital input. But most normal 5.1 PC systems will have three 3.5mm inputs: green for fronts, black for rears, orange for sub and center. Is your system like that? Or you have just one 3.5mm input?
If you have 3 inputs, this is what you need:http://www.amazon.com/dp/B00F9HS7MW/..._hojQtb1GWTV1K
scorrpio is offline
post #4 of 4 Old 06-23-2014, 03:57 PM - Thread Starter
Liked: 0
Scorrpio, that is exactly what I need, yes it has 3 3.5mm inputs!
That will do the job perfectly - thank you!!
Also thank you William for your comments, appreciate it.
