AVS/AIX High-Resolution Audio Test: Ready, Set, Go! - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #1 of 222 Old 06-30-2014, 11:06 AM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1503 Post(s)
Liked: 4189
AVS Forum and AIX Records invite you to participate in an experiment to see if bona fide high-res audio can be reliably distinguished from CD specifications.
The question of whether or not real high-resolution audio can be reliably distinguished from CD audio is a fascinating one—and not easily answered. To explore this question, I would like to enlist the help of AVS members who have audio systems capable of reproducing that difference.
But before I get to the experiment itself, I'd like to share some of the conclusions I've come to after posting several threads about it and reading the hundreds of comments they inspired. (If you haven't read them already, be sure to check out the threads on whether or not high-res audio is irrelevant, the high-res test initial and refined proposal, and amirm's high-res audio debate thread.)
1. The source material must be real high-res audio. The content must include frequencies well above 20 kHz and a dynamic range greater than 93 dB (CD's effective maximum after dithering to deal with quantization noise), and it must be recorded, edited, mastered, and delivered with at least 24-bit/96 kHz resolution. (I'm not going to consider DSD/SACD for this particular experiment.)
2. The playback system must be capable of reproducing the high-res material at full resolution, including the source device, DAC, amplifier, and speakers. The entire system must have a frequency response well above 20 kHz and a dynamic range greater than 93 dB.
3. Very few consumer systems are capable of reproducing frequencies above 20 kHz and a dynamic range greater than 93 dB, so trying to compare a real high-res recording with a CD-quality version of the same material on such a system is pointless. There will be no acoustic difference between the two files (other than perhaps some distortion if the level of the 24/96 content exceeds 93 dB), so there is no possibility of a perceptible difference between them.
4. It is unlikely that the human auditory system can directly perceive frequencies much above 20 kHz. However, there could be other mechanisms that allow humans to perceive ultrasonic frequencies. For example, those frequencies might interact and produce difference or interference tones in the audible range. Also, it could be that ultrasonic frequencies can be detected by other parts of the anatomy, such as the skin. So even if we can't "hear" ultrasonic frequencies directly, their presence might make a perceptible contribution to our sonic experience.
5. It is unknown if headphones can be used in lieu of speakers. Some headphones are specified to reproduce ultrasonic frequencies, but that is often in a free field, not on the ears, and I know of no independent measurements that verify ultrasonic performance in use. Also, if ultrasonic frequencies are detected by other parts of the anatomy, that mechanism won't work with headphones. (New anecdotal evidence suggests that some headphones might work, which I'll explain shortly.)
The Setup
Mark Waldrep (aka Dr. AIX), founder and chief engineer of AIX Records, has prepared three full-length tracks from his catalog that contain ultrasonic frequencies and wider-than-CD dynamic range. The original recordings were recorded, edited, and mastered at 24/96. The tracks have not been dynamically altered, and all metadata have been removed. Each clip has also been downsampled to 16 bits/44.1 kHz, the resolution of Redbook CD audio, using the "gentlest" triangular PDF algorithm in Sonic Studio's Sonic Process, a state-of-the-art sample-rate converter. Then, the downsampled version was upsampled back to 24/96 without adding audio data that wasn't in the lower-res file, making it easier to compare the two versions and more difficult to tell them apart by casual inspection of their file sizes. All files are in uncompressed WAV format.
Here are spectrograms from each track, showing both the 24/96 (red) and 16/44.1 (yellow) versions:
"Mosaic" from Guitar Noir by Laurence Juber
"Just My Imagination" from Stand by Wallace Roney
"On the Street Where You Live" from Tormé Sings Tormé by Steve March Tormé
We realize that putting one version through two sample-rate conversions—even state-of-the-art conversions—will raise some eyebrows, and we are concerned that this could somehow introduce artifacts that might make it easier to distinguish the sound of the converted file. The other alternative was to downconvert the 24/96 file to 16/44.1, then convert both files to analog and back to digital at 24/96 using state-of-the-art DACs (digital-to-analog converters) and ADCs (analog-to-digital converters), but this also would have raised eyebrows by introducing multiple digital/analog conversions. In the end, we decided to go with the double sample-rate conversion to keep everything in the digital domain.
The two versions of each clip are labeled A and B, and which one is 24/96 has been randomly selected for each track with a coin toss. The files are available for anyone to download at the end of this article.
System Requirements
Anyone can download the files and give a listen, but if you'd like to contribute data to the experiment, you need an audio system that is capable of reproducing the extra information in the 24/96 file. (UPDATE: This requirement has been eliminated; see the update note below for more.) What are the required specs? Let's start with system configuration. Basically, the fewer components in the signal chain, the better, so we think the best setup is a source computer connected via USB to a high-quality DAC. The DAC would be connected directly to a power amp, which would, of course, drive the speakers.
The best system configuration for the AVS/AIX high-res audio test is a computer sending 24/96 data to a high-performance DAC that is connected directly to a power amp feeding the speakers.
Of course, there must be an analog volume control after the digital-to-analog conversion to adjust the listening level; this can't be done in the digital domain because it would reduce the number of bits being used. Some DACs include such a control on their analog output, and some power amps provide level controls. If neither component in your system has this control, you must insert an analog preamp between the DAC and power amp.
Obviously, the computer must be able to output native 24/96 via USB, and the DAC must be able to convert that to analog without downsampling. Also, while virtually all DACs use very high internal rates, the output of the digital section must remain at the original 24/96. The analog output of the DAC must be able to support ultrasonic frequencies up to near 48 kHz and a dynamic range greater than 93 dB, and the preamp (if used) and power amp must have similar frequency-response and dynamic-range specs from input to output. Finally, the speakers must be able to reproduce those ultrasonic frequencies and wide dynamic range with minimal distortion.
As we were preparing for this experiment, Mark Waldrep tried playing the files using ABXTester on a Macintosh computer with a Benchmark DAC1 (which has an analog volume control) and Oppo PM-1 headphones, which are spec'd to reach 50 kHz in a free field. To his surprise, he was able to hear a clear difference between the A and B files, indicating that the experiment can be performed with these headphones and DAC—and, thus, probably others as well.
UPDATE: After much consideration, we've decided to eliminate the requirement that participants have a truly high resolution-capable audio system. Instead, anyone can submit their determinations to me via PM, but they must also include a list of equipment in their system (source, DAC, preamp, power amp, speakers or headphones). I am compiling separate results for true HRA systems and non-HRA systems to see what that might suggest.
The Experiment
To perform the experiment, all you need to do is play each file as many times as you wish and decide which one is high-res and which is limited to CD specs. Some have suggested that listeners use an ABX program such as foobar2000 for Windows or ABXTester for the Mac, both of which are free. However, each of these programs (and other similar software) operate somewhat differently from each other and return results that aren't exactly what we're looking for.
You can certainly use these programs to play the files if you like; in fact, the optional ABX Comparator module for foobar2000 makes it easy to switch between the two versions seamlessly during playback, which might help you make up your mind. (ABX Comparator also randomly assigns the files you identify as A and B to the labels X and Y as part of a double-blind test, but we're not using that functionality of the program in this case.)
After deciding whether the A or B version of each track is high res, you can send your determinations to me by PM with the subject line "AVS/AIX HRA Test." If you can prove that your system is capable of reproducing the extra information in the 24/96 versions—and some of you have already sent me your system specs—I'll include your determinations in the experimental data. Then, I will calculate the percentage of correct responses; if the versions are identified correctly much more than 50% of the time (the result expected by random chance), it would suggest that high-res audio can be discerned from CD audio, at least when played on an appropriate system.
Of course, the system requirements are pretty stringent, which means that for most people, high-res audio is irrelevant, at least in terms of perception. On the other hand, if you compare a commercial CD and a high-res file of the same music, the high-res version might well sound different—perhaps better—because it might have been mastered differently than the CD. But we are investigating whether or not the extra information in a well-recorded high-res audio file can be reliably perceived compared with a CD version of the exact same file.
Because there are so many uncontrolled variables—different systems, different rooms—this experiment cannot be considered a rigorous scientific test by any means. Even more important, we have no way of verifying that participants aren't cheating by examining the spectra of the files and/or misinforming us about the capabilities of their systems. All we can do is appeal to your sense of fairness and honesty in the spirit of scientific inquiry. We believe this is an interesting exercise, and we hope you can participate.
To download the files, simply click on the links below. All files have been zipped individually so that browsers initiate a download rather than try to play the files; in addition, all six files have been zipped into a single file so you can download them all at once with one click. (These are big files—the combined file is nearly 1 GB—so it could take some time to download them, depending on your bandwidth.)
Let the listening begin!
UPDATE: After some members identified a 0.2 dB difference in level between the native 24/96 and sample-rate converted versions of each track, we level-matched them and reposted all files as "Take 2." The updated files are available by clicking below.
All in one:
AVS/AIX HRA Test Files 2
Individual files:
Mosaic A2
Mosaic B2
Just My Imagination A2
Just My Imagination B2
On The Street Where You Live A2
On The Street Where You Live B2
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
amirm, Frank Derks, TVOD and 6 others like this.
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
post #2 of 222 Old 06-30-2014, 12:39 PM
CharlesJ's Avatar
Quoted: 449 Post(s)
Liked: 267
Looks interesting.
Let the testing begin...
CharlesJ is offline
post #3 of 222 Old 06-30-2014, 01:05 PM
DrMichael's Avatar
Quoted: 116 Post(s)
Liked: 85
Dumb question but how do you know if your system has that much dynamic range?
DrMichael is online now
post #4 of 222 Old 06-30-2014, 01:38 PM
JimShaw's Avatar
Quoted: 315 Post(s)
Liked: 351
I would have loved to give it a try. My problem is: I am not that computer wise. I down loaded the zip files but I am not able to transfer them to a CD to place into my Oppo player.
But like I said: I am not wise on what to do. I am probably doing it wrong.
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 6 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Samsung UN78JS9500,. LG OLED55E6P
Oppo UHD-203 player, Denon X7200WA, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
post #5 of 222 Old 06-30-2014, 01:43 PM
Frank Derks's Avatar
Quoted: 447 Post(s)
Liked: 328
Use a USB memory stick.
Frank Derks is online now
post #6 of 222 Old 06-30-2014, 02:03 PM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
what's about that _MACOSX folder?
mightyhuhn is offline
post #7 of 222 Old 06-30-2014, 02:14 PM
isa
Quoted: 33 Post(s)
ummm, Waldrep emphatically did NOT detect a difference between the two files. In fact, he couldn't have been more incorrect. His interpretation that he guessed incorrectly on every single sample meant that he actually got them all correct reveals he knows NOTHING about ABX. Absolutely nothing. More than one commenter in his blog even warned him about his egregious misinterpretation.
If you want to completely invalidate everything with this test, ignore this post.
isa is offline
post #8 of 222 Old 06-30-2014, 02:22 PM
JWhip's Avatar
Quoted: 586 Post(s)
Liked: 724
The fact that the engineer who recorded, mixed and mastered the recordings can't tell the difference speaks volumes. I have the Juber recording at 24/96 and it does sound superb. I don't have the CD though.
JWhip is offline
post #9 of 222 Old 06-30-2014, 02:46 PM
JimShaw's Avatar
Quoted: 315 Post(s)
Liked: 351
That I have and thanks
JimShaw is offline
post #10 of 222 Old 06-30-2014, 02:53 PM - Thread Starter
Liked: 4189
What about it? Where do you see it? I know of no such folder...
Scott Wilkinson
Editor, AVS Forum
post #11 of 222 Old 06-30-2014, 02:55 PM - Thread Starter
Liked: 4189
i just started testing it and stopped at Just_My_Imagination_B.wav because Just_My_Imagination_A.wav has very loud background noise it's simply impossible not to hear it it's so loud and always the same noise. in a ABX i need only 2 clicks in 1 sec to make the right choice...
even if Just_My_Imagination_A.wav is the high res version i highly highly pref Just_My_Imagination_B.wav
so is this a mastering error of some kind or what is happening here?
Hmmm, I don't know; I will investigate...
Scott Wilkinson
Editor, AVS Forum
post #12 of 222 Old 06-30-2014, 02:56 PM
WayneJoy's Avatar
Quoted: 126 Post(s)
Liked: 81
I can't even get Just My Imagination A to extract. I think something is wrong with the file.
WayneJoy is offline
post #13 of 222 Old 06-30-2014, 03:06 PM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
i found out what that is these are invisible folders on mac osx, on windows they are visible.
there are 6 300 byte+ files in as wave with the same name the test file have. so looks like they are simply cache data from mac or something like that.
i check this file with different playback system to make sure there is nothing wrong with my system.
maybe a CRC should be added to all file or at least posted in the thread from the creator. but if the file is corrupted you normally got some else as added noise.
a CRC for the zip file should be enough if i think about it
post #14 of 222 Old 06-30-2014, 03:18 PM - Thread Starter
Liked: 4189
I just downloaded both versions of Just My Imagination and listened to both all the way through. They both extracted without problems, and I hear no background noise on either one. I'm on a Mac running OSX 10.6.8. I only listened through the computer's headphone output just to see if there was a problem, and I didn't hear one.
Scott Wilkinson
Editor, AVS Forum
post #15 of 222 Old 06-30-2014, 03:23 PM - Thread Starter
Liked: 4189
Hmm, well, the files were put together on a Mac and sent to AVS for posting from a Mac, so maybe that's where the invisible folder comes from. For now, just ignore any such folders and files.
I'll ask about adding a CRC to the files...stand by.
Scott Wilkinson
Editor, AVS Forum
post #16 of 222 Old 06-30-2014, 03:47 PM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
i did some checks.
this isn't happening with ASIO but with WASAPI (my default) and DS.
so it would be nice if someone could test this on his Windows PC.
WASAPI and ASIO should be Bit perfect.
i played the file back with my "TV SPEAKER" and i can't hear this problem.
i try a different playback program tomorrow.
Foobar2000 and MPC-BE WASAPI have this problem for me.
i can simply use ASIO so i don't have a real problem anymore but why is this happening.
post #17 of 222 Old 06-30-2014, 04:16 PM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 242
It's ok, it's just a Windows thing. As that folder is invisible to us Mac users.
Originally Posted by Fenton
Macs (which are now Unix) store various info, window options, etc. in little files which are normally invisible on Macs, but which show up on Windows. One thing you can do is use a utility to remove them before sending files to Windows clients. There are various free programs; the one I've been using is CleanArchiver, with the "zip" option. Leave it on your Dock, then just drop folders on it.
http://www.sopht.jp/cleanarchiver/
http://fmforums.com/forum/topic/47465-macosx-folder/
xvfx is offline
post #18 of 222 Old 06-30-2014, 05:37 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 79
On the spectrogram for "Just My Imagination", what is that big peak at 44khz?
TVOD is offline
post #19 of 222 Old 06-30-2014, 06:09 PM
HowardV's Avatar
Quoted: 68 Post(s)
Liked: 52
First, I LOVE AIX records. I have several of their recordings (Blu-Ray, DVD, and iTraxx downloads). I love them because they make quality multi-channel recordings. Furthermore, they provide them with different perspectives (audience and stage). My preference is always the stage perspective. I have 5 full range speakers and their multi-channel recordings sound tremendous.
I downloaded the test tracks on this thread and just finished listening to them. I could not tell the difference. Both sounded wonderful. I used Foobar with an Oppo 105 as a DAC. I don't think the rest of my system meets all the requirements (McIntosh MX-119 pre-amp, Spectron Class D amp, and Gallo Reference 3.5 speakers).
Edit: Please ignore this as I misread the original post: "If I understand correctly, the original 24/96 files were downsampled to 16/44 and then upsampled to 24/96 again? Isn't this an unfair test? You've limited what the 24/96 files can produce by downsampling it. And that information can't be gotten back by upsampling again. Am I missing something?"
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
2 Anthony Gallo Reference SA Amps
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
post #20 of 222 Old 06-30-2014, 06:37 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 79
I thought that was the point: Comparing the original hi-res file to one that had gone through the Redbook CD audio 16/44 format to see if there is an audible difference.
TVOD is offline
post #21 of 222 Old 06-30-2014, 06:42 PM
WayneJoy's Avatar
Quoted: 126 Post(s)
Liked: 81
Yes, I'm on a PC, I extracted the files with the functionality built into Windows 7. All other files extracted correctly. I had a problem with the one file in both the individual and the complete downloads.
WayneJoy is offline
post #22 of 222 Old 06-30-2014, 06:52 PM
HowardV's Avatar
Quoted: 68 Post(s)
Liked: 52
Errr...nevermind. I misread the original post. You are correct. One file is the original 24/96 and the other is downsampled to 16/44 and upsampled to 24/96. Makes sense. I'll go up and edit my post.
Both files sounded the exact same to my ears.
HowardV is offline
post #23 of 222 Old 06-30-2014, 07:44 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Just a friendly reminder, one *right* way to compare them is to use the FOOBAR2000 ABX Comparator. It will keep them in synch as you switch back and forth which most people find optimizes listener sensitivity. Because its an ABX Comparator you can do the test sighted or double blind with the same tool.
arnyk is offline
post #24 of 222 Old 06-30-2014, 09:46 PM
HowardV's Avatar
Quoted: 68 Post(s)
Liked: 52
Thanks! I'll install the ABX Comparator and give it another shot tomorrow. I just used the back and forth (next track up/down) to compare the beginnings and couldn't tell the difference.
I had done this test before on the Audiogon "Wake Up Your Ears" sampler released through HDTracks some time ago. I purchased both the 16/44 and the 24/192 versions. This was my own personal test of high res vs. regular and I still couldn't tell the difference.
HowardV is offline
post #25 of 222 Old 06-30-2014, 11:00 PM
Kees de Visser's Avatar
Quoted: 24 Post(s)
Scott, I noticed two problems with the testfiles:
1) The pairs are not sample accurately aligned. This is essential for seamless ABX switching.
2) There is a 0.2 dB level difference between the hi-res and lo-res versions.
These issues can cause false positives and can be easily corrected IMNSHO.
Kees de Visser is offline
post #26 of 222 Old 06-30-2014, 11:05 PM - Thread Starter
Liked: 4189
I'll ask Mark about this.
Scott Wilkinson
Editor, AVS Forum
post #27 of 222 Old 07-01-2014, 04:49 AM
Quoted: 447 Post(s)
Liked: 328
Just PM'd my results.
post #28 of 222 Old 07-01-2014, 05:11 AM
isa
Quoted: 33 Post(s)
There is no minimum number of trials recommended or specified in "The Experiment" section above. I'd recommend users conduct at least 10 trials. Each user should submit the same number of trials each to make aggregation of results easier.
isa is offline
post #29 of 222 Old 07-01-2014, 07:54 AM
granroth's Avatar
Quoted: 667 Post(s)
Liked: 451
I agree with Waldrep's interpretation of his results, in this case. To those who don't follow his blog/daily emails, he did the test with ABX Tester on a Mac and came up with a 0% success rate. He asserts that that is equivalent to getting 100% since he clearly just switched around A and B in his head.
That makes sense to me. If he truly couldn't tell the difference then we'd expect to get somewhere closer to 50% (but not exactly that, since ABX Tester doesn't work like that). One of the core ideas of ABX testing is that it's statistically unlikely to blindly guess which file is which with 100% accuracy. Well, it's statistically precisely just as unlikely to blindly guess them all incorrectly.
So rejecting his test because he got 0% on it is no different than rejecting it if he had gotten 100% -- both are identically unlikely to happen by chance.
(I'm not sure why Waldrep didn't just re-do the test a second time, just to alleviate this confusion)
granroth is offline
post #30 of 222 Old 07-01-2014, 08:21 AM
Quoted: 447 Post(s)
Liked: 328
ABX testing without knowing A and B is not good. You may get 100% but you still need to identify A or B to determine which is the hires track.
He may have passed the ABX testing proofing he could hear a difference between A and B but he could not identify the correct track.
You can call this equivalent to 100% but you can also state the he showed a preference for the 'lo-res' tracks despite being able to successfully ABX between the two tracks.
With three tracks the sample size is too small for a high enough confidence level.
After submitting my results through PM I checked the files with Auditions spectrograph. (Identified 3 in a row correctly )
However so far I could not successfully ABX the tracks while knowing which of the two was the hires track.
(With foobar ABX the first selected track is always under button 'A' )
frontpage
