Window Plug / Bass Absorption Combo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-04-2014, 06:25 AM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
We recently bought new furniture which required us to move my living room / theater around. With the new setup, there is a large window directly behind the LP. I need to build a plug to block as much sound as possible, but also need bass absorption due to my couch being close to the wall.
For the window plug, I was planning to use three layers of 1/2 drywall with green glue between each. For bass absorption, I thought about adding 6" of pink fluffy insulation.
Do you think my plan will work?
sslv2pwned is offline
post #2 of 6 Old 07-04-2014, 06:46 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I would suggest that you use two layers of drywall with 3" of fiberglass in between; a sandwich.
commsysman is offline
post #3 of 6 Old 07-04-2014, 07:07 AM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
For sound proofing or bass absorption? I would think that green glue is much better at blocking ULF than 3" of fiberglass.
post #4 of 6 Old 07-19-2014, 05:09 PM
stef2's Avatar
Quoted: 332 Post(s)
Liked: 212
I would go with mass, and green glue. Dont bother about bass absorption since 3 inches of fiberglass will do absolutely nothing to absorb bass.
stef2 is offline
post #5 of 6 Old 07-19-2014, 06:49 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
As many layers of drywall as you can with Green Glue between each one. Fiberglass is worthless for converting acoustic energy to heat.
William is offline
post #6 of 6 Old 07-19-2014, 08:13 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
I already told him that weeks ago in the other thread he opened up in the other forum section. Hopefully he listened to the advice and it was successful.
I recommended 3 inches of solid MDF and green glue (1" sheets), if that doesn't stop the bass... then that is where you give up, as nothing will stop bass short of 30ft of solid gold burried inside the base of the pyramids of giza with all the shafts and openings sealed with cement. LOL
BassThatHz is offline
