Impedance and sound. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-08-2014, 03:08 PM - Thread Starter
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1686
While speaker impedances are within a few ohms of each other, the same is not true of headphones. Headphones vary from impedances similar to those in speakers up into the hundreds of ohms or more.
Since amplifiers are designed with a given output impedance does sound reproduction vary with the input impedance of headphones?
FMW is offline
post #2 of 12 Old 07-08-2014, 05:52 PM
Glimmie's Avatar
Quoted: 738 Post(s)
Liked: 604
It shouldn't with most solid state output stages which have impedaces in the fractions of ohms. Now if you are using a tube headphone amp, then there might be a sonic difference as tube amps have higher output impedance and the loading of the output transformer effects the feedback loop (if one is used).
Glimmie is offline
post #3 of 12 Old 07-09-2014, 03:08 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
The above is a bit of an over simplification. Amplifiers are designed to drive minimum impedances, and handle higher impedances wonderfully.
The same is true of headphone amps. The ones that drive low impedance headphones well, drive higher impedance headphones well.
arnyk is offline
post #4 of 12 Old 07-09-2014, 03:49 AM - Thread Starter
FMW
FMW's Avatar
Liked: 1686
Thanks guys. I'm trying to figure out where all the headphone amp sound signature claims come from. I'll assume it is no different than the same claims we hear about amps that drive speakers. I ordered some new headphones for the computer. My plan was and still is to drive them with the receiver that powers my computer speakers. No need for a headphone amp. Take care.
FMW is offline
post #5 of 12 Old 07-09-2014, 04:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Fact is that while a tiny minority of high end audiophiles use SETs to drive speakers despite their high source impedances, headphone amps that provide a source impedance that is high enough to cause audible coloration are pretty common.
A lot of AVRs drive their headphone jacks with dedicated headphone amps, which can be positive for a nice low source impedance, but there are no guarantees.
When in doubt get a Fiio E5 headphone amp for a < $25 which pretty well guarantees a low source impedance, or measure the impedance of the headphone jack that you have.
Here is a good paper on the topic:
http://test.benchmarkmedia.com/discu...nce-Part-2.pdf
arnyk is offline
post #6 of 12 Old 07-09-2014, 06:57 AM - Thread Starter
FMW
FMW's Avatar
Liked: 1686
I understand. Thanks. I ordered a pair of 600 ohm planar magnetic cans and just wanted to make sure my existing receiver and preamp headphone jacks would handle things properly.
FMW is offline
post #7 of 12 Old 07-09-2014, 02:16 PM
12B4A's Avatar
Quoted: 287 Post(s)
Liked: 161
What are the sensitivity of the headphones? You may run in to a situation where you might not have enough voltage out to provide enough power at that ohm value.
12B4A is offline
post #8 of 12 Old 07-10-2014, 06:29 AM - Thread Starter
FMW
FMW's Avatar
Liked: 1686
That isn't a problem. I think using an Ipod to power them might be a challenge but I'm not worried about a stereo receiver being able to handle the job.
FMW is offline
post #9 of 12 Old 07-10-2014, 06:34 AM
12B4A's Avatar
Quoted: 287 Post(s)
Liked: 161
High probability it will work out. If not, there's always the Hammond 119DA.
12B4A is offline
post #10 of 12 Old 07-18-2014, 04:05 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Although ironically not true for your profile pic--the HE-400:
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 12 Old 07-18-2014, 05:57 PM - Thread Starter
FMW
FMW's Avatar
Liked: 1686
Pretty stable I would say. I didn't mean that the impedance changes a lot with frequency. Obviously it doesn't. I meant that the rated input impedance can cover a wide range. My headphones are rated at 32 ohms although, apparently, your graph shows them at 50 ohms. Some of the popular phones are up in the hundreds of ohms for an input impedance.
The frequency response of the HE-400 certainly doesn't look like that graph. This headphone has a U shaped response curve with a depressed midrange and peaked bass and treble. The sound is calm and luscious. A bit dark with lots of detail in the high treble. You have to spend a whole lot more to do much better than these. These are at a sweet spot in the price/performance curve. Try a pair. They are very nice.
So what is your cat wearing?
FMW is offline
post #12 of 12 Old 07-18-2014, 06:22 PM
cel4145's Avatar
Liked: 2991
Sorry. I misunderstood that you meant that headphones have wide impedance variance. And many do. Just not the HiFiMan planar magnetics
Not my cat. That's a Sony April fool's day image: http://mashable.com/2013/04/01/sony-animalia/
cel4145 is offline
