sticking speaker wire to baseboards? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-08-2014, 03:16 PM - Thread Starter
ryewhiskey's Avatar
Quoted: 25 Post(s)
We just rearranged our living room, and for a number of different reasons, I'm planning to run the wires (Monoprice 14 AWG) along the baseboards around the periphery of the room.
Can anybody suggest a good, efficient way to discreetly stick the wires to the baseboards? I don't want to use nails, staples, screws or plastic guides, but I'm afraid double-sided tape isn't going to be strong enough to hold the wires firmly in place. I'd like to find some kind of little adhesive dot I could stick the wires to, kind of like the little felt pads used for the bottom of furniture only with adhesive on both sides. I also thought about a hot glue gun, but I'd don't have to have to buy one just for this project.
Any thoughts?
ryewhiskey is offline
post #2 of 5 Old 07-08-2014, 07:30 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
I have some double sided foam tape that is extremely sticky...
Maybe this: http://www.amazon.com/Scotch-Mountin.../dp/B00004Z498
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #3 of 5 Old 07-09-2014, 04:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Any thoughts?
Scotch industrial strength double sided tape is pretty tenacious, and I think they still carry it at Staples. If you get it pressed onto the baseboards really tight, the paint might come off with it if you try to remove it later on. I give it a shot with a heat gun to maximize the adhesion.
http://www.amazon.com/Scotch%C2%AE-D.../dp/B001O6NLXW
Thing is, you can get a cheap hot melt glue gun at craft store for about the same amount of money.
arnyk is offline
post #4 of 5 Old 07-09-2014, 06:04 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Have you considered pulling the carpet back an inch or so and running the wire under the actual baseboards? If your room is carpeted then most baseboards will be slightly elevated off the sub floor or concrete in order to allow the carpet to be poked under them. It's actually pretty easy to do this.
Martycool007 is offline
post #5 of 5 Old 07-09-2014, 05:37 PM - Thread Starter
ryewhiskey's Avatar
Quoted: 25 Post(s)
Thanks for the replies. I didn't realize there was such a thing as foam and industrial strength doubled-sided tape. If the clear tape is really as strong as it purports, that could be just what I was looking for. Unfortunately, this is for a room with hardwood floors, so lifting the carpet isn't an option.
