Details on the decoding process - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-17-2014, 12:19 PM - Thread Starter
nathanzachary's Avatar
Question Details on the decoding process
Hello all,
I have a question that has been in the back of my mind for a long time now. Here's the setup:
media server --> sound card --> Toslink --> pre-amp
I built my media server, and it is essentially just a Linux server running MPD. MPD streams my FLAC files (which I ripped directly from my CDs) to an Asus Xonar DX sound card, and then sends them out via the card's Toslink to the pre-amp.
I'm wondering where the decoding actually happens? My understanding is that it flows like this:
media server (obviously, still FLAC files) --> decoded into PCM by media server (libflac) and sent to sound card --> PCM sent via Toslink cable to pre-amp --> PCM converted to analogue via the pre-amp's DACs
Does that seem accurate? If so, the DACs on the sound card shouldn't be used at all, right?
Basically, I'm just trying to figure out the process, so I can obtain the "purest / least altered" sound, and would like a deeper understanding.
Thank you preemptively.
Cheers,
Nathan Zachary
nathanzachary is offline
post #2 of 5 Old 07-17-2014, 01:11 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
If by pre-amp you mean processor/pre-amp, i.e. one that has digital toslink input, then yes, what you say is correct. Media Server is performing the decode and sending the PCM samples over Toslink. The sound card DAC is not used.
amirm is offline
post #3 of 5 Old 07-17-2014, 02:02 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
If so, take a look at the driver selections available. Some permit, others restrict, data manipulations (change sample rate or bit depth, or add equalization or other effects) to be performed at the PC before the PCM is transmitted to the AVR.
My win7 machine under various playback softwares shows selections for at least these choices, not all of which I understand myself:
MME
DirectSound
ASIO
WASAPI event mode
WASAPI push mode
Kernal
Foobar Choices:
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #4 of 5 Old 07-17-2014, 05:57 PM - Thread Starter
Thank you both for your input! Regarding the driver, I believe that my only option will be the in-kernel driver for AV100. I can choose different output devices, but in this case, I would think that the SPDIF (Toslink) would be the choice that I would want.
Thanks again!
post #5 of 5 Old 07-17-2014, 11:20 PM
BassThatHz's Avatar
Quoted: 2043 Post(s)
Liked: 1573
ASIO should be the most direct.
WASAPI would be second best.
BassThatHz is offline
